Engine swap question...
To swap a D16Z6 engine into a 91 crx si do I need to rewire it for OBD1 (or buy the harness)?, and would it just be easier doing a mini me setup?
TIA
TIA
hi ok u need the computer, 92-95 ex coumputer which is better the 95-on.
u need jumper wire that plugs in to ur crx si ecu wiring then in to 92-95 ex ecu ( it will cost about $200)
need to hook up the vtec solenoid ( it is about three wire )
re wire ur distrubutor
will for the best of my knowledge some told me that, that was i need to do to my crx91
si dude just go with dohc zc non vetec it will bolt right in and pretty much u can use ur stock wiring and the ecu. i think i going with the zc dohc my self. good luck
