Alternator belt changing.....
Old Nov 10, 2003 | 01:16 PM
BrandonClaps's Avatar
New User
Default Alternator belt changing.....
I need to change the alternator belt on a 97 civic ex. I was looking in my helms, i just have one question. In the helms it says deflection method and belt tension gauge method. Does that mean you can check the belt with either method, or must be checked with both methods?
Old Nov 10, 2003 | 03:17 PM
New User
Default Re: Alternator belt changing..... (BrandonClaps)
ttt
Old Nov 10, 2003 | 03:25 PM
Evs-One's Avatar
Solbros Owns Me
I just go by feel
Old Nov 10, 2003 | 08:25 PM
New User
Default Re: Alternator belt changing..... (Emerika)
lol, is it hard to do by yourself, i've never done really engine work besides puttin on mods i/h/e suspension. Do i have to do anything besides undo the 2 bolts on the alternator?
Old Nov 10, 2003 | 09:38 PM
cxSHOE's Avatar
just do what the manual says, follow it exactly.. and you will be fine..
Old Nov 10, 2003 | 10:08 PM
Spartanic's Avatar
Its acutally pretty easy, all you gotta do is loosen the big bolt on the alternator bracket, then you can swivel the alternator towards the engine and the belt will loosen up and then you can just remove it. You are supposed to install the belt with some kind of tool so that you can achieve the proper tension but I just go by the feel. If it feels tight and not loose then its good.
t_mac
14
Dec 21, 2008 01:20 PM
Fook_me_honda
Sep 21, 2005 01:28 AM
failed
Sep 4, 2005 05:59 AM
B2FiNiTY
14
Sep 24, 2003 01:17 PM
babyviper97
Jan 27, 2003 01:17 PM
