i wanna lower my car.. the right way!
Old Nov 10, 2003 | 11:31 AM
ieatrice's Avatar
Default i wanna lower my car.. the right way!
ok, right now im lowered on adjustable generic coilovers.. and it bounces like hell. i have stock struts and i was wondering what lowering springs would ride nice on stock struts. i want a nice drop, but definitely not slammed. btw, i'm on a budget. some help would be nice! also, i've used the search and it got me nowhere.. i'm on 56k.
Old Nov 10, 2003 | 11:33 AM
GsR HtCh's Avatar
Default Re: i wanna lower my car.. the right way! (ieatrice)
skunk2 coilovers are not bad. have you considered lowering springs?
Old Nov 10, 2003 | 11:36 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: i wanna lower my car.. the right way! (GsR HtCh)
right way + budget = not going to be very right.
To do it 100% the right way is full coilovers, or springs/struts. Just an FYI.
Old Nov 10, 2003 | 11:38 AM
ieatrice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 coilovers are not bad. have you considered lowering springs?</TD></TR></TABLE>
i'm looking for some right now.. i'm low on cash, and i just want a nice set of lowering springs that will ride nice on stock struts.
Old Nov 10, 2003 | 11:40 AM
EARLdaSQUIRREL's Avatar
official honda whore
well chances are if your using hte cheap coilvoers on your stock struts right now they arent any good anymore......
just save up your money, ride on shitty coilovers and stock shocks untill you can afford a good setup
Old Nov 10, 2003 | 11:42 AM
ieatrice's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">well chances are if your using hte cheap coilvoers on your stock struts right now they arent any good anymore......
just save up your money, ride on shitty coilovers and stock shocks untill you can afford a good setup</TD></TR></TABLE>
yeah.. but i'm not a ricer, ok? haha, i didn't lower the car like that to start with. i just bought the 95 hatch not too long ago, and it came like that. i guess i'll ride on these suckers for a lil' bit longer while i save up. ::sigh::
Old Nov 10, 2003 | 11:46 AM
Navid OG's Avatar
Default Re: (ieatrice)
how much do u want to spend?
Old Nov 10, 2003 | 11:55 AM
Jason C SBB's Avatar
If you want HANDLING, then lowering the car is NOT the first step.
If your shocks are old or blown, the first step would be Koni yellows
The next step is a rear swaybar, or a matched set of front and rear swaybars.
Then, increase caster in the front, by swapping the front upper control arms left-to-right (this works on an EK, not sure about EG's), and maybe getting caster-increasing front LCA rear bushings from Superpro.
My money is where my mouth is.
On my EK, in order of largest improvement to smallest:
- Koni yellows
- ST swaybars
- swap upper UCAs
- ES shifter bushings (improves driving pleasure, not handling)
- H&R OE sport springs (with Koni height adjustability, (lowers car max 1.25")
- Superpro bushings in front LCA rear location
- ES steering rack bushings
Only the spring swap degraded ride quality, and the ride quality degradation was larger than the improvement in handling.
Modified by Jason C SBB at 11:17 PM 11/10/2003
Old Nov 10, 2003 | 12:29 PM
Archidictus's Avatar
Unceasing Measure
Default Re: i wanna lower my car.. the right way! (Jason C SBB)
Tein S-Tech's are cheap and high quality. They work really well with aftermarket struts, so when you decide to do it right (I.E. not the way you're doing it now ), you'll have decent springs.
Old Nov 10, 2003 | 12:33 PM
-[95cxhatch]-'s Avatar
Default Re: i wanna lower my car.. the right way! (Archidictus)
for a good cheap setup get some ground control coil overs about 300 shipped and some kyb gr-2 struts about 275 shipped from summit racing.com thats what i have on my car and it rides kinda rough but thats what you get for having stiff springs with any coil over set.
Old Nov 10, 2003 | 01:08 PM
Carlo's Avatar
Using stock shocks is bad, they will eventually blow. Blown shocks = bouncy ride. If you want to lowe ryour car the right way, you have to get the right springs as well as the right dampers.
Old Nov 10, 2003 | 01:25 PM
ieatrice's Avatar
gotcha.
BLeSR
May 7, 2010 12:33 AM
shelbyEK!
Suspension & Brakes
Sep 17, 2009 08:57 AM
Nino_eg6
Jun 24, 2008 07:51 PM
Chillmatic
44
Apr 6, 2008 07:30 PM
em1_racer
39
May 20, 2007 07:09 PM
