p28 ecu
short and simple question...
i have 97 civic with a 01 gsr swap...will a p28 ecu work fine or do i have to get a p72 (gsr) ecu? the reason being is cause the p28 is already chipped so i would like to keep it but i heard only the p72 ecu will work with the secondary butterflies on the gsr manifold.
Modified by ddong2lee at 11:09 PM 11/10/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">If i was in your situation id just keep the p28 and save up for an aftermarket intake manifold and do away with the secondaries.</TD></TR></TABLE>
yea i was thinking about just getting a skunk2 intake manifold to get rid of the secondary butterflies...
any comments on those or any other intake manifolds?
actually i dont quite remember...just did the swap this weekend and its at my friends house...cuz he's tweakin some things up...ill find out some time this week...i know its a p28 chipped in NY to 5000 rpm to vtec and 9000 to rev limiter...or somewhere around those numbers...
i sent it out to locash racing and they changed the fuel maps, rev limt, enabled the iab's and switched the vtec crossover to the same specs as a p72. only thing it doesnt have is the knock sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ex »</TD></TR><TR><TD CLASS="quote">i sent it out to locash racing and they changed the fuel maps, rev limt, enabled the iab's and switched the vtec crossover to the same specs as a p72. only thing it doesnt have is the knock sensor.</TD></TR></TABLE>
local guy, Joe knows his ****.
aiite guys..i decided not to deal with secondary butterflies and just buy a skunk2 intake manifold...now heres my question..
should i stick with my chipped p28 or go with a jun chipped p72?
WAIT FOR THE AEBS INTAKE MANIFOLD AND KEEP THE P28!!!! Search and you will see that it has outperformed the Skunk2 on b16 and ITR motors. Also, there is no need to buy another ecu if you already have one that works fine. The only advantage of the p72 is the fact that it will control the butterflys which you will no longer have.
Zion-I
Feb 12, 2006 09:32 PM
maxheat
10
Feb 9, 2005 12:55 PM
sicilian2k1
Aug 5, 2001 11:06 PM
