2000 Si engine into 2000 EX
Old Nov 10, 2003 | 05:46 AM
m0dr0cker's Avatar
Default 2000 Si engine into 2000 EX
I've been searching the board trying to figure out which engine the 2000 Civic Si has and how easy it would be to transplant my EX's d16 with the Si's engine.
I know a lot of you are prolly going to tell me to swap in a bigger, more powerful engine, but the reason I'm looking at the Si's motor is because I figure the surrounding hardware of the Si and EX are pretty much the same, so it should be relatively easy to replace the engine. I think.
Also, I'd be content at 160 HP since I'm semi-environmentally-conscious and I really like getting exceptional gas mileage out of my Civic.
Unless, of course, anybody knows of another engine I could swap in that would also not require replacing/modifying a bunch of the surrounding hardware or electrical components.
The Si engine (what is it??), is it DOHC?
Thanks in advance.
Old Nov 10, 2003 | 05:49 AM
michael O's Avatar
The si engine is a b16a2? I believe.
Old Nov 10, 2003 | 06:41 AM
Built2.0Lude's Avatar
yeah its a b16... That engine would be just fine, a lot of people go with the b16... You say 2000 si engine, do you already have the engine?
Old Nov 10, 2003 | 06:50 AM
m0dr0cker's Avatar
Default Re: (Vtec96Lude)
Thanks for the feedback guys.
No, I don't have the engine, although from reading other posts concerning the b16, it doesn't seem that expensive to get. I've read things about OBD I vs. OBD II. If I grab a b16 off of a '00 Si, the OBD should be compatible with the '00 EX, right?
P.S., what is OBD?
Old Nov 10, 2003 | 07:24 AM
Echo7847's Avatar
Default Re: (m0dr0cker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m0dr0cker &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the feedback guys.
P.S., what is OBD?
On Board Diagnostics, and yes you want to be looking for an obd2 engine.
Old Nov 10, 2003 | 09:29 AM
Jon D's Avatar
Default Re: 2000 Si engine into 2000 EX (m0dr0cker)
Yeah your definitely looking for a b16a2...............i dont know exactly what obd means but it varies with ecu's. like my p73 ecu for my type r motor is obd2....where as a lot of people tend to swap there obd2 with an obd1 that comes out of 94-95 gsr's. I would worry about finding your motor first and someone who can install in correctly the first time.
Old Nov 10, 2003 | 09:57 AM
Quimbs
Guest
Posts: n/a
Default Re: 2000 Si engine into 2000 EX (jh4dc23spoon)
I say buy a b16b rather then spend 2800 on an OBD2 B16A2 which are expensive. The guys at Japan Star have the b16b for 3200.00.
Old Nov 10, 2003 | 10:21 AM
m0dr0cker's Avatar
Default Re: 2000 Si engine into 2000 EX (Homey Da Clown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Homey Da Clown &raquo;</TD></TR><TR><TD CLASS="quote">I say buy a b16b rather then spend 2800 on an OBD2 B16A2 which are expensive. The guys at Japan Star have the b16b for 3200.00. </TD></TR></TABLE>
What's the difference between the 16b and 16a2?
Old Nov 10, 2003 | 10:23 AM
Quimbs
Guest
Posts: n/a
25 HP is the diff great auto x motor revs very high
Old Nov 10, 2003 | 03:38 PM
VTECVillain's Avatar
The 99-00 Si has the B16A2 and OBD2B electronics which makes it plug and play compatible with your EX. The B16A2 is rated 160hp and is a 1.6L DOHC VTEC engine with a close ratio 5 speed tranny. This would be a direct bolt in to your car assuming that you get a complete conversion: complete motor, tranny, ECU, axles, shift linkage, etc.
There are many other choices besides the B16A2 Si swap. A B18C1 Integra GSR motor which has more displacement, making more power and noticeably more torque is also an excellent swap as well. Do some research on here and I'm sure you'll be able to narrow your choices down.
Old Nov 11, 2003 | 07:07 AM
m0dr0cker's Avatar
Default Re: 2000 Si engine into 2000 EX (VTECVillain)
Thanks for the information!
em1Cr3w
Sep 3, 2010 11:58 AM
George_ORH
17
Jul 21, 2005 09:18 AM
coronaflyest718
Jun 4, 2005 09:47 AM
inane
29
Jun 22, 2004 05:20 AM
