could someone please post a pic of the pcv valve on an integra ls?? thanks
Old Sep 9, 2001 | 03:05 PM
DamonBoost's Avatar
New User
Default could someone please post a pic of the pcv valve on an integra ls?? thanks
I am having hard time locating it on my car.. If you could post a pic that would be awesome and greatly apprecited....
Old Sep 9, 2001 | 03:45 PM
boost killz's Avatar
New User
Default Re: could someone please post a pic of the pcv valve on an integra ls?? thanks (ill logic)
Ill man if you look at the back of your engine close to the firewall below your intake manifold you should see a red colored valve with a hose attached to top side of the vale and the other plugged into the bottom end of the engine into a grommet piece. Pull it out of the gromet piece first and try to pull it out of the hose without to much force because the hose can be slightly dry and you can easily break it due to the dryness, good luck hope that description could help.
Peace
Nick
Old Sep 9, 2001 | 03:52 PM
DamonBoost's Avatar
New User
Default Re: could someone please post a pic of the pcv valve on an integra ls?? thanks (boost killz)
thanks man. are u sure mine is in the same place and is red?
Old Sep 9, 2001 | 06:49 PM
New User
yeah man it is...
lancerkid06
Mar 11, 2024 09:53 AM
O2BESOHUGE
Nov 26, 2013 07:32 PM
TonyRomo
Mar 31, 2010 08:39 PM
Stadler
Jun 27, 2008 02:26 PM
