5th and reverse, whered you go?
Old Nov 9, 2003 | 09:44 PM
that_guy's Avatar
Default 5th and reverse, whered you go?
the car: 90 crx dx with a b16a, J1 cable transmission, Clutchmasters stage 3 clutch (less that a year old), HD pressure plate, and 7.5 flywheel. Hasport mounts and custom shift linkage
The problem: Just today i noticed a time or two that i was shifting into 3rd when i was trying to shift into fifth. it also ground when i did an aggressive shift into third (it usually doesnt). So trying to back out of my girlfriends driveway tonight i find that reverse is nowhere to be ...missing. After pushing the car out to where i can drive away, i get on the freeway to find that to get into fifth i have to use quite a bit of muscle to shove the shifter in the far top right hand corner to get it into gear. Also there is a ton of play (to the right) in third and fourth gear. Its pretty hard to not have a reverse so ive got to get some ideas of what this is going to be and see about getting it fixed. Im hoping it isnt the shift fork, as getting one for a J1 may present a problem for me. The unusual grind into third makes me wonder if i just may be low on my manual transmission fluid. The amount of play in fourth and third makes me think it may also be a problem with my shift linkage. Any ideas would be greatly appreciated. thanks
Old Nov 9, 2003 | 09:51 PM
RiceRacist's Avatar
Default Re: 5th and reverse, whered you go? (that_guy)
Definetely top off the tranny fluid and if that doesnt do anything I would think its the shift fork. Sounds very costly though
Old Nov 10, 2003 | 06:47 AM
that_guy's Avatar
Default Re: 5th and reverse, whered you go? (RiceRacist)
im inclined to thinking (hoping) that it has something to do with my shift linkage, because i can still a. it 5th and reverse together, and b. i am actually able to find 5th occationally. i should just be able to get under it and see if the shift linkage is tight, right?
eriki
Apr 15, 2013 04:44 AM
eriki
Transmission & Drivetrain
Apr 14, 2013 04:13 PM
nick lsvtec
Feb 17, 2008 05:04 AM
alexisthemovie
Dec 30, 2006 03:33 AM
4gen
Aug 11, 2004 04:29 PM
