Rod knock in cold weather ? only when starts up.
Old Nov 9, 2003 | 08:21 PM
Chemicalviper's Avatar
Default Rod knock in cold weather ? only when starts up.
Ok about beginning/towards middle of summer i bent a valve when i mishifted at the track and had the head redone basically stock - except dpr dual valve springs, 00si retainers - just didnt have the money at the time to upgrade.
Nothing has been the matter for the past few months its been running. But ever since it hit 22 degrees. I notice rod knock for not even 2 seconds when i start the car. Then it dissapears immediatly and I never hear it again. Of course its hard to hear it going 70 mph but i try to listen as much as possible and I dont believe there is a knock.
Its only when its been cold out. And when the motor has been sitting for over 6 hours.
Never did this before. I havent redlined or mishifted or non of that crap. But there is the possibility I created stress on the bearing from that mishift in summer ? and why would it only be affected in the winter...
I will be posting up a video possibly tuesday night cuz im a overlyworried teg owner hehe.
Any insight would be great on the present situation.
Old Nov 9, 2003 | 08:59 PM
King_j's Avatar
Default Re: Rod knock in cold weather ? only when starts up. (Chemicalviper)
are you sure its a rod knock and not a ticking noise, such as a valve?
Old Nov 9, 2003 | 09:00 PM
I know what valve tap sounds like ... trust me hehe.
Its not injectors either even though they click.
Its not chattery like valve tap and loud injectors. Its clear rod knock. Its got that knock sound lol - i will post on tuesday.
Also its not pinging either.
Old Nov 9, 2003 | 09:05 PM
King_j's Avatar
Default Re: (Chemicalviper)
looks like you have a nice little job on your hands
no more mis-shifting
Old Nov 9, 2003 | 09:51 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: (King_j)
i think rod knock would worsen as its driven and gotten louder within a few days. if its been past this time already, chances are its somethign else. you'd notice after driving around 3-4 days if it was rod-knock or not, especially after some highway use.
Old Nov 10, 2003 | 12:22 PM
Its been like this for a week/ couple weeks - hasnt gotten worse, its actually lessened. But still there
Old Nov 10, 2003 | 02:35 PM
Stewie's Avatar
I don't think you can have rod knock a startup only. At startup, the oil pressure is higher than when the enging is warm. The more oil pressure, the more stable the rod is.
Are you sure your not hearing piston slap? Are you burning alot of oil?
Piston to valve contact does put high loads on the bearing and rods themselves. Maybe you slightly bent a rod and has caused the piston rings to wear down, inceasing the cylinder wall clearance and is why your hearing piston slap at idle.
Old Nov 10, 2003 | 02:43 PM
Default Re: (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote"> Are you burning alot of oil? </TD></TR></TABLE>
An abnormally higher amount.
I mean i changed the oil not even 2 weeks ago with mobil 1 5w30 synthetic
And it was right at the lowest dot. But i heard from the top dot to the low dot is only one quart.
Old Nov 10, 2003 | 04:13 PM
Stewie's Avatar
Default Re: (typeR0059)
I suggest that you do a leakdown test and see if you find a cyl with high leakage. If that's the case, next time you start the engine pull the plug wire and see if the noise goes away. See what I'm getting at?
Next, you can narrow the problem further down by checking the oil pressure.
Old Nov 10, 2003 | 04:19 PM
I see what your saying - I understand the knock will still continue very shortly after i shut off the car.
Also - I have extended warranty on my car but i also have FPR and VAFC .. now i can get the vafc out and off - but i dont know what todo about the FPR
Old Nov 11, 2003 | 04:04 PM
95cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper &raquo;</TD></TR><TR><TD CLASS="quote">Ok about beginning/towards middle of summer i bent a valve when i mishifted at the track and had the head redone basically stock - except dpr dual valve springs, 00si retainers - just didnt have the money at the time to upgrade.
you mean bent 7 valves?
Old Nov 11, 2003 | 05:04 PM
87cquest's Avatar
lifter tick possibly. exhaust leaks can make a knock sound until the car warms up. If it were a rod I would guess your oil pressure would be very low, and you'd run pretty hot. friends trans am had this problem. It was his flywheel.
Old Nov 12, 2003 | 05:47 PM
95cx's Avatar
Default Re: (87cquest)
Uhh chris i never wrote that. Somone at B's is doing that. I try not to be a dick like that
Old Nov 12, 2003 | 07:35 PM
StyleTEG's Avatar
Default Re: (95cx)
piston slap
its actually pretty common on honda engines from what I have seen.
Something along the lines of when the engine is cold, the worn piston rings allow the piston to slap around in the cylinder slightly causing that clacking noise. When it warms up, everything expands and the pistons are held snug again.
Old Nov 12, 2003 | 07:39 PM
Default Re: (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">piston slap
Something along the lines of when the engine is cold, the worn piston rings allow the piston to slap around in the cylinder slightly causing that clacking noise. When it warms up, everything expands and the pistons are held snug again.</TD></TR></TABLE>
Sounds exactly right from what ive researched
preludeboybmw
Sep 29, 2010 04:21 PM
nonvtec92
16
Jun 14, 2008 08:19 PM
bigplayj17
Apr 13, 2007 09:31 AM
aNt408
Feb 18, 2006 08:40 PM
