Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Modifying chromoly cage... must I use chromoly?
Old Nov 9, 2003 | 07:49 PM
Civic44's Avatar
Default Modifying chromoly cage... must I use chromoly?
I want to add a couple of bars to my basic 6-point cage. It's 1.5 inch chromoly. Must I use chromoly for the new bars? one end of each bar will be welded to the main hoop, the other end to the chassis. Thanks.
Old Nov 10, 2003 | 02:28 AM
jc836's Avatar
Default Re: Modifying chromoly cage... must I use chromoly? (Civic44)
Basically-yes. Chromoly is not the same as mild steel. Keep in mind that it also is prone to cracking in high stress areas. You should do an annual inspection of the cage using proper techniques to insure weld integrity. This happens to be the downside of the material versus mild steel. Unless you can insure the quality of the welds and their structural integrity-stick with the same material thruout the cage.
Old Nov 10, 2003 | 09:11 AM
ITC Racer's Avatar
Default Re: Modifying chromoly cage... must I use chromoly? (jc836)
I believe Chrome-moly matieral needs to be normalized after welding or special proceedures need to be followed or the tubing will not be as strong as referred to above.
Agtronic
Welding / Fabrication
46
Jan 26, 2009 09:51 AM
Unique Artwerkz
Oct 26, 2007 02:00 PM
tsiah
Apr 15, 2007 08:32 PM
EGJDM
Mar 9, 2004 12:43 PM
