b16 speedometer cable....(i searched)
Old Nov 9, 2003 | 04:38 PM
HatchBox's Avatar
Skoobie no more...
Default b16 speedometer cable....(i searched)
ok well everyone says just plug it in, but on my buddys b16 there isnt a hole. but rather a clip. so is there anyways i can switch the speedometer sensor from a dx to the b16? or does my friend need a newer cluster that recognizes the digial sensor and some custom wiring?
Old Nov 9, 2003 | 04:42 PM
my_slow_civic's Avatar
Default Re: b16 speedometer cable....(i searched) (ind3ciso)
Sounds like his tranny has the VSS plug setup, and you need the cable sensor, right? If so, no, you cannot use one off a DX tranny, you need a manual speed sensor, from a B series tranny.
(I happen to have one sitting here if you need. )
Old Nov 9, 2003 | 04:44 PM
HatchBox's Avatar
Skoobie no more...
Default Re: b16 speedometer cable....(i searched) (my_slow_civic)
u my helpfull friend have
Old Nov 9, 2003 | 07:26 PM
biggdogg's Avatar
i did a swap for afriend and his hsd the elctronic vss . all i did was pull the cable drive one outta his 91 si hb tranny and put it in the new b-series tranny . it worked perfect.
Old Nov 9, 2003 | 10:50 PM
spaceman's Avatar
i have an 88 crx si/jdm b16/s1 and when i got the motor it had the jdm speedcable on it and it was trying to look high tech and **** with hoses comin off of it..i just gave that jdm contraption the boot and put my stock speedcable in the whole and it works fine...good luck
Old Nov 10, 2003 | 04:13 AM
Lsos's Avatar
Yeah I just used the manual one from the original tranny. No problem. I'm not sure how the ecu gets a speed signal like that, but apparently it does....
Old Nov 10, 2003 | 09:50 AM
Default Re: b16 speedometer cable....(i searched) (biggdogg)
Hmm.. whenever I look at my D series tranny, there is no way to pull the sensor out.
Old Nov 10, 2003 | 09:51 AM
Lsos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">Hmm.. whenever I look at my D series tranny, there is no way to pull the sensor out.</TD></TR></TABLE>
I think I remember it looking like that as well. You can do it though.
Old Nov 10, 2003 | 01:08 PM
raene's Avatar
Default Re: b16 speedometer cable....(i searched) (Lsos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsos &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I just used the manual one from the original tranny. No problem. I'm not sure how the ecu gets a speed signal like that, but apparently it does....</TD></TR></TABLE>
The VSS is actually inside your gauge cluster on the older cars, rather than inside the transmission.
There should be a 10mm bolt on the VSS, that's all that holds it into the transmission. Remove the 10mm bolt and remove the assembly (it will pop out with some twisting).
Old Nov 23, 2003 | 04:46 PM
HatchBox's Avatar
Skoobie no more...
anybody got the the cable driven unit? pm me
Old Nov 23, 2003 | 05:18 PM
HatchBox's Avatar
Skoobie no more...
i will either buy one or ...if someone would like to trade my electronic VSS for the Cable driven one that would be awesome, im on the honda-tech good sellers list so no need to worry i just need it ASAP.
thanks guys!
Old Nov 23, 2003 | 10:18 PM
raene's Avatar
Me me me! PM me!
I have a DX unit and B16A unit... I'm going to try the DX in my B16A. If it works, then I'll sell you the B16 unit.
Both work fine, I just want an electronic VSS.
Old Nov 24, 2003 | 03:11 AM
HatchBox's Avatar
Skoobie no more...
Default Re: b16 speedometer cable....(i searched) (raene)
alright sounds good
Del_Slo_b16
Aug 3, 2012 08:05 AM
alscrx
Jun 14, 2007 08:50 PM
B89HatchSi
11
Nov 17, 2005 09:52 PM
Vincent.
Aug 30, 2004 01:23 PM
sleeperls93
Sep 3, 2003 05:18 AM
