Is this setup good enough for 12's
Old Nov 9, 2003 | 01:54 PM
ALLphilthyDC2's Avatar
Default Is this setup good enough for 12's
B18C1 (US 98 Spec)
95 ITR tranny w/ a 98 ITR Spec Final drive ratio
Ported GSR intake manifold
Port n Polish Head
Skunk2 Valvetrain(springs,retainers,etc...)
Skunk2 Stage 2's(w/cam gears, etc...)
Itr rod's w/ PR3 Piston's
JDM ITR Header
Hondata S200 ECU or Skunk2
MSD Ignition Setup w/ tha 2 Stepper
This Setup right here rollin on 13x8 bogey's(22inch or 23inch slicks???) w/ the skinnies on the rear
Is this enough to be hittin 12's...or please let me know what you think???
Old Nov 9, 2003 | 02:09 PM
JCushing's Avatar
Default Re: Is this setup good enough for 12's (Philthy415)
you might wan to mention the car/weight
Old Nov 9, 2003 | 10:37 PM
on a 98 gsr...what weight savings do you recommend w/o sacrificing good driveablity
Old Nov 9, 2003 | 10:41 PM
gsrvx's Avatar
New User
yup..good enough
Old Nov 9, 2003 | 10:42 PM
AussieK24's Avatar
You MIGHT run a 13....
Old Nov 10, 2003 | 03:52 AM
slammed_93_hatch's Avatar
Default Re: (AussieK24)
id say do anything you can to drop the car down to around 2100lbs that will help alot, gsr is loaded with weight auto windows sunroof, abs, all that **** well (you might want to keep the abs) but i would say get ride of all the sunroof **** you can, loose the auto windows strip the interior strip the sound deading material, and maybe the 5mph bumber safty thing
Old Nov 10, 2003 | 01:10 PM
Junkiii Ek's Avatar
possible 12's good luck man!
TwistedHatch
Oct 21, 2003 03:38 AM
lke2drvgsr
Oct 15, 2003 04:17 PM
LSVTEC408
Jun 10, 2002 06:52 PM
MXPX
Jan 30, 2002 12:35 PM
