My New Motor has arrived 12sec Build UP
Old Nov 9, 2003 | 12:36 PM
bossman032's Avatar
Default My New Motor has arrived 12sec Build UP
my first step in getting closer to 12sec all motor!!
what motor is it anyone?
Old Nov 9, 2003 | 12:57 PM
Eggman's Avatar
Default Re: My New Motor has arrived 12sec Build UP (bossman032)
b16b or b18c-r? either way its a type r motor, in the first pic you can see the green paint, on the head by the dist...dead give away.
Old Nov 9, 2003 | 01:04 PM
d styles's Avatar
Default Re: My New Motor has arrived 12sec Build UP (Eggman)
doch vtec motor
Old Nov 9, 2003 | 01:25 PM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman &raquo;</TD></TR><TR><TD CLASS="quote">b16b or b18c-r? either way its a type r motor, in the first pic you can see the green paint, on the head by the dist...dead give away. </TD></TR></TABLE>
yes civic type R motor.
Old Nov 9, 2003 | 03:20 PM
Timmah!!'s Avatar
What green paint?
Old Nov 9, 2003 | 03:35 PM
bossman032's Avatar
Default Re: My New Motor has arrived 12sec Build UP (azroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">
What green paint?</TD></TR></TABLE>
look at the first picture see that slight green!!
Old Nov 9, 2003 | 03:47 PM
sir2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">
look at the first picture see that slight green!! </TD></TR></TABLE>
no
Old Nov 9, 2003 | 03:54 PM
bossman032's Avatar
Default Re: My New Motor has arrived 12sec Build UP (sir2k)
ok to bad then
Old Nov 9, 2003 | 04:00 PM
EG8R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">ok to bad then </TD></TR></TABLE>
I think you need to get off the green if you do see green in those pics
Old Nov 9, 2003 | 04:06 PM
bossman032's Avatar
Default Re: My New Motor has arrived 12sec Build UP (skelly ed6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 &raquo;</TD></TR><TR><TD CLASS="quote">
I think you need to get off the green if you do see green in those pics </TD></TR></TABLE>
haha I think u should get on the green too see the green
Old Nov 9, 2003 | 04:12 PM
realfasthonda's Avatar
dont see the green either......... 12 sec huh? what all is going to be done and why did you pick a ctr motor?
Old Nov 9, 2003 | 04:36 PM
bossman032's Avatar
Default Re: My New Motor has arrived 12sec Build UP (realfasthonda)
CTR because I want to reach my goal with a CTR motor.
I want to get some head work done. Get some toda Cams Or Spoon and valve train upgrade and a Good header. Any recommendations anyone that has experience..?
I got the motor at a very good deal I didn't want to spend another 3G just going 1.8
anyways help me out guys recommendations
Old Nov 9, 2003 | 05:08 PM
SIINSI's Avatar
Good luck with it man and congrats on the motor.
12 Seconds on a B16B NA will not be an easy task. You will almost certainly need some serious bottom end work as well as some nice lumpy cams I think if you sleeve it, larger bore, P & P and some nice cams and lots of tuning, you *may* hit very high 12's. Without bottom end work, I would say it will be hard to say the least.
Best of luck
Miguel
Old Nov 9, 2003 | 05:09 PM
Project91CRX's Avatar
why is it green?
Old Nov 9, 2003 | 05:19 PM
Nerologic's Avatar
hmmm 12's are way possibble with probper tunning on the stock block i have a beesixteenie that i am running constant 13.1's at the local 1/4 mile track (carlsbad) and i figuered out messing with the suspension bettered my times just as much as meesing with the engine, so i cee 12's easy with a good chip or tunning not to mention some good slicks
Old Nov 9, 2003 | 05:28 PM
bossman032's Avatar
Default Re: (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic &raquo;</TD></TR><TR><TD CLASS="quote">hmmm 12's are way possibble with probper tunning on the stock block i have a beesixteenie that i am running constant 13.1's at the local 1/4 mile track (carlsbad) and i figuered out messing with the suspension bettered my times just as much as meesing with the engine, so i cee 12's easy with a good chip or tunning not to mention some good slicks</TD></TR></TABLE>
nice whats ur mods?
Old Nov 9, 2003 | 06:18 PM
xlr8civic's Avatar
would love to have that motor in my civic! very nice!
Old Nov 9, 2003 | 08:39 PM
CunninLynguist's Avatar
Default Re: My New Motor has arrived 12sec Build UP (Kikomon)
In your first pic.
Inside of the head there are little marks inside. What would be the cause of this?
My swap looks like that in the head too.
Old Nov 9, 2003 | 08:49 PM
rice_classic's Avatar
But you have a 1.8... it's just disguised as a 1.6. The CTR motor is a DE-stroked 1.8. All you need is the b18c5 Crankshaft and PRESTO (at least this what I understand from my honda-tech research)
Old Nov 10, 2003 | 04:04 AM
sircrxracer's Avatar
Default Re: My New Motor has arrived 12sec Build UP (rice_classic)
I see the green just slightly, and I see the valve springs on the exhaust side which are blue... I would say that's a ITR head aleast. Rob
Old Nov 10, 2003 | 05:02 AM
johnzm's Avatar
Default Re: My New Motor has arrived 12sec Build UP (sircrxracer)
its EASY to hit 12's
go look for omniman's b16 buildup on the allmotor forum. 200whp is 12's with a driver
Rice Ball
19
Jan 24, 2013 10:12 PM
fatboy01
Honda Motorcycles
16
Mar 12, 2008 10:38 AM
mr. biggles
Oct 28, 2006 11:29 AM
Rocket
93
Jul 27, 2004 06:52 PM
