Overfilled Oil
Old Nov 9, 2003 | 11:13 AM
zomart's Avatar
Default Overfilled Oil
this morning i checked my oil level before i drove the car at all (had been sitting for at least 12 hours) and the level was high! it wasn't extremely high, but about 1/8 to 1/4 of an inch above the top hole. when i drove it out of my garage (like 30 seconds of driving) the level went down to about 1/4 an inch above the lower hole. i'm pretty sure the level should never go above the top hole, but i just want to make sure... should i still drain some or is it normal for the level to be high when the car has been sitting that long?
Old Nov 9, 2003 | 11:25 AM
SuzukaBlueAP2's Avatar
Default Re: Overfilled Oil (zomart)
Maybe it's just me...but I'd rather be a tad over than a tad under on my dipstick.
Old Nov 9, 2003 | 11:31 AM
SubieDude's Avatar
Default Re: Overfilled Oil (urbanracer98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe it's just me...but I'd rather be a tad over than a tad under on my dipstick.
i agree i would like to be over a little too
Old Nov 9, 2003 | 11:35 AM
zomart's Avatar
Default Re: Overfilled Oil (WhiteS2)
sweet.. so just leave it?
also, is it normal for the level to go down that fast (after driving it for 30 seconds). i would expect the oil to take longer to circulate through the engine.
Old Nov 9, 2003 | 01:25 PM
King_j's Avatar
ok, do you know how to check oil?
the engine must be off for about 5 minutes for the majority of the oil to settle at the bottom.
3 quarts of oil fill up to the bottom hole. between the bottom hole and the top hole, it takes about 1 quart.
if you are slightly over it wont matter, but a 1/4 inch? i dont think i would want that much EXTRA oil in my engine.
Old Nov 9, 2003 | 01:26 PM
gsr-2nr's Avatar
Default Re: Overfilled Oil (King_j)
if you want to lower it just go around and hit vtec a LOT or drain some if you really want to
Old Nov 9, 2003 | 01:35 PM
Tweakmeister's Avatar
Default Re: Overfilled Oil (gsr-2nr)
loosen the filter and drain some.
you do not want it over the top hole.
Old Nov 9, 2003 | 01:39 PM
zomart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King_j &raquo;</TD></TR><TR><TD CLASS="quote">ok, do you know how to check oil?</TD></TR></TABLE>
yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King_j &raquo;</TD></TR><TR><TD CLASS="quote">the engine must be off for about 5 minutes for the majority of the oil to settle at the bottom.</TD></TR></TABLE>
i know. i didn't say anything about the time for the oil to drain down into the pan, i asked about how quickly the oil was circulated out of the pan.
thanks.
invisible
21
Dec 27, 2006 08:27 AM
EJK20R
Honda Civic (2006 - 2015)
Nov 28, 2006 11:13 AM
YoungKadafi
10
Jul 21, 2006 08:17 AM
hondaimport99
Aug 20, 2005 01:06 PM
RGoose18
Nov 10, 2003 02:33 AM
