JDM swap legal in cali?
Old Nov 9, 2003 | 10:48 AM
silvernick711's Avatar
Default JDM swap legal in cali?
I was wondering what it takes to make a jdm swap legal/ smog legal in cali?I've searched on this and have found nothing.Thanks!
-Nick
Old Nov 9, 2003 | 11:53 AM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
most likely no...
Old Nov 9, 2003 | 01:23 PM
gsr-2nr's Avatar
Default Re: (SpoodgeDc2)
in cali hahaha hell no with all their emmissions and smog BS that would no way b legal
Old Nov 9, 2003 | 01:32 PM
SiR831's Avatar
Default Re: (gsr-2nr)
I know of 2 people who reff'd 1st Gen JDM B16a motors in thier 92-95 civic. All they did was use the OBD1 US Del Sol intake manifold, all US smog devices, and ecu.
Old Nov 9, 2003 | 01:39 PM
threatcon13's Avatar
New User
Default Re: JDM swap legal in cali? (silvernick711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvernick711 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering what it takes to make a jdm swap legal/ smog legal in cali?I've searched on this and have found nothing.Thanks!
-Nick</TD></TR></TABLE> You need to take it to the smog ref...use usdm ecu and cat.
Old Nov 9, 2003 | 01:47 PM
Downey's Avatar
yes, as long as u have a US ECU that matches the engine so for a B16, use a Del Sol VTEC P30 ECU. make sure u have a stock cat. change your oil before u go to the ref.
Old Nov 9, 2003 | 01:48 PM
Mt3c's Avatar
25 Year Member
it is possible as long as it's not a truck engine (crv b20), and you use the correct smog devices. that includes ecu, intake manifold, intake, header and cat. try a search the archives in the civc forum, they have lots of information on this, and several have done it.
Old Nov 9, 2003 | 03:00 PM
EIT_certified's Avatar
Default Re: JDM swap legal in cali? (Mt3c)
yeah I was a dumbass and tried to smog my lsvtec teg. The co2 legal level was about 856 and the car put out about 3572. I was told that is mainly because of the fact that there is too much compression. I have reprogrammed ecu and burning extra gas doesn't help either.
Old Nov 9, 2003 | 03:11 PM
babes 99 GSR's Avatar
Default Re: JDM swap legal in cali? (sheemo3)
^^ Well ****. What are you doing about it?
-Staci
Old Nov 9, 2003 | 04:47 PM
:jdmshmaydm:'s Avatar
Default Re: JDM swap legal in cali? (99GSR1980)
Damn Cali's too strict with that. Down here you can swap any JDM motor and be on the road like nothing.
Old Nov 9, 2003 | 05:15 PM
Newman's Avatar
New User
Default Re: JDM swap legal in cali? (Threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> You need to take it to the smog ref...use usdm ecu and cat. </TD></TR></TABLE>
Correct, as it's already been done numerous times with lots of different motors (from 1st gen B16A swaps in a CRX to a JDM H22A swap in an EG Civic). But like I always say, it's also going to depend on YOUR smog tech and how he's feeling that day and whether or not he wants to pass you or not.
Old Nov 9, 2003 | 05:34 PM
riceball777's Avatar
nothing is legal here in cali but i dont even care any more just do illegal smog
i just do illegal smog so i dont need to worry about the after market stuff i put on my car
Old Nov 16, 2003 | 09:55 PM
PRoJecTSLeePaLoT's Avatar
Default Re: JDM swap legal in cali? (riceball777)
I might want to do a jdm b18c or c5 into my hatch... my bro has a usdm 95 gsr. So all I need to do is swap in his parts into my car and i'll pass state ref???
Old Nov 16, 2003 | 10:30 PM
96dc2's Avatar
Default Re: JDM swap legal in cali? (PRoJecTSLeePaLoT)
search the Hybrid and EG forum for "BAR". You'll find what you need. Also, go to the CARB website.
Modified by 96dc2 at 12:02 AM 11/17/2003
Old Nov 16, 2003 | 10:40 PM
slowww b18b1's Avatar
Default Re: JDM swap legal in cali? (96dc2)
n e one know of under the table smoggin in san diego???
Old Nov 16, 2003 | 11:31 PM
opeth13's Avatar
Default Re: JDM swap legal in cali? (B18B1-turbo)
wow, are you serious?
Old Nov 17, 2003 | 01:56 AM
JDM_Honda_Fiend's Avatar
Default Re: JDM swap legal in cali? (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">
Correct, as it's already been done numerous times with lots of different motors (from 1st gen B16A swaps in a CRX to a JDM H22A swap in an EG Civic). But like I always say, it's also going to depend on YOUR smog tech and how he's feeling that day and whether or not he wants to pass you or not.</TD></TR></TABLE>
Yep that's correct, most emission techs are moody. If they feel like they want to do it they will do it for you but most likely it's going to be an under-the-table deal. The only problem is that most of the refs will pass the inspection test for you but when it gets on the emissions dyno, your motor better pass. I have an LS/VTEC set up fully built from the ground up and I just got my smog done a lil while ago. I was very close to failing the emissions test but it was surprising to see that it passed. Now it's pretty hard to find a tech that will take your paperwork and use another vehicle to smog unless you know the guy personally. But your best bet is to go around and ask, I'm sure there's someone that will do it for you if you show them some green. If they are those people that make you run your car on the dyno as I did, make sure you have a clean working O2 sensor and pop on a really restrictive cat on your car. It could mean passing or failing from my experience. Good luck though
Cheers
Old Nov 17, 2003 | 06:31 AM
Teggy94's Avatar
**** the smog!
hondacivic90zc
14
Mar 10, 2007 12:03 AM
gsr916
May 6, 2005 10:18 PM
SuperDuude
Oct 26, 2004 11:26 PM
weakGOODJunKieS.com
Sep 28, 2002 11:03 AM
