Stupid codes that just wont go away!
Ok, I am trying my d**ndest to rid myself of engine problems here. I took out the RC injectors cause I was getting a code 16 and figured they were dumping to much fuel or something, I installed a pefectly good set of stockers and still a code 16. So its not injectors. Anyone have any idea's of what else could cause a code 16?
While we are at it, I got all the vacume lines properly hooked up and a new map sensor, there is still a code 13 (Could this actualy be my PA sensor?)
It also apears that I am now getting a code 7 (Throttle angle) I did adjust my tps and I am going to do it again and see if this cant be fixed that way, anything else cause this code that you guys know of?
Seth.
Seth.
Wiring is good, I been down that rout 50 times now, thoe the injector resistor box had crossed my mind I didnt realy think they went bad so I descided that wasnt the problem... Do those things burn out?
pokemon
Jul 26, 2003 09:24 AM
