Thrust Clearances for ITR LSD
Old Nov 8, 2003 | 09:51 PM
DOHCsideracing's Avatar
Default Thrust Clearances for ITR LSD
H-T patrons:
I am in the middle of putting a ITR LSD in my GS-R tranny, and ran into a bit of a snag. The '95 GS-R uses tapered roller bearings, and the ITR uses angular contact bearings (basically ball bearings), and they aren't 100% compatible.
Does anyone have a ITR factory service manual that they can give me the clearances that I should shim the ITR bearings to? I have found an online version of the '97+ Civic manual, which uses similar bearings, and they list .000"-.004" clearance, but I would like to make sure of the clearance instead of just assuming...
If it is at all possible if someone could scan in those few pages, and post them or e-mails them to me that would be an extra huge favor.
Thanks in advance,
Adrian R.
SA TX
'93 del Sol Si w/ a '95 GS-R swap. Turbo on the way...
samuraijackass
Transmission & Drivetrain
22
Feb 21, 2011 09:15 PM
SpeedHoles49068
Oct 4, 2006 08:10 AM
mike1114
Mar 26, 2005 06:47 PM
Ls1 FD3s
Feb 26, 2005 10:22 AM
mingchi69
Feb 17, 2004 09:39 AM
