help needed fast!!
Old Nov 8, 2003 | 09:44 PM
juanb's Avatar
Default help needed fast!!
i was driving to the track and i was getting off the exit i put my turing signal on and all of a sudden my rpms stoped working, my gas gauge stoped working, my temperature gauge stoped working, my clock stoped working, my heater stoped working, and my turning signals dont work, but my emergency lights work??? the lights in my cluster worked but the next day they didnt, i put many different fuses in the slot for my turning signals and it blew everysingle one of them, also i put some in the slot for my reverse lights and that one blew them too!! has this happened to anyone before or does anyone know what could of happened?? also does anyone know where i can find a pretty acurate diagram to my wires so i can go back and check those??
any help is greatly appreciated
thank you
Old Nov 8, 2003 | 09:53 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: help needed fast!! (juanb)
check your grounds.....
Old Nov 8, 2003 | 10:23 PM
juanb's Avatar
do you know exactly where the grounds are?
thanks
Old Nov 9, 2003 | 04:43 AM
juanb's Avatar
bump .. i need help fast
Old Nov 11, 2003 | 05:40 AM
juanb's Avatar
bump
Old Nov 11, 2003 | 01:24 PM
chadmasterc's Avatar
Default Re: (juanb)
there are three all together i believe. there is one on top of the tranny. And there is the obvious one that connects to the valve cover. Not sure about the third.
Old Nov 11, 2003 | 01:59 PM
jc836's Avatar
Get a Helm for the wiring or stop by your dealership and see if they will let you copy from theirs. There is a module on the back of the underdash fusebox that controls much of what you mention. If you can start the car-then something in that area is shorting out. Did you install an aftermarket stereo of any sort-check it carefully. Make sure that all of the wiring to your speakers, and accessories that you may have put in are connected properly.
Old Nov 11, 2003 | 06:56 PM
juanb's Avatar
hey thanks, i did have a system installed but its out now and it has been out for about 1 month so i dont know if thats the problem i did look at the module on the back of the underdash fuse box and i think that may be the problem b/c i disconnected all the plugs going to the cluster and my turning signals and when i put in a fuse it still blew them. bo im going to try a friends in my car maybe that will do the trick but thanks for your advise
Old Nov 11, 2003 | 09:57 PM
Lucifer6i9's Avatar
its a hot wire touching a ground that keeps blowing your fuses. if you cut up any wires or have any cut up wires make sure to tape them up, thats what i had to do because i kept blowing fuses so i taped up every wire that was exposed
Old Nov 12, 2003 | 06:24 PM
juanb's Avatar
ok i tried a good working fuse box from my friends crx, and still problem it still blew the turning signal fuse and it still didnt work!!! does anyone know where i can get a wiring diagram?
hey lucifer6i9 u said this happened to u or what happened? cause i dont have any cut up wires touching anything. the only thing i had that was cut touching anything was my REMOTE wire for my amp. but i dont think that was the think that messed everything up
thanks
Old Nov 12, 2003 | 10:33 PM
Lucifer6i9's Avatar
Default Re: (juanb)
what happened to me was my dash lights went out , and tha rear running lights went out (same fuse) i couldnt figure out why i kept on blowing fuses . i dont have front turn signal lights because there cut up wires so i just figured i should tape them up and ever since than i havent blown a fuse. but tha same thing happened to me i just kept blowing fuses as soon as i put them in until i taped up them wires . i still dont get how the turn signal wires in tha front would blow the fuse to the dash lights and rear running lights but hey it works now
Old Nov 12, 2003 | 10:34 PM
Lucifer6i9's Avatar
Default Re: (Lucifer6i9)
when you got off the exit did you hit any bumps or run over anything that could of jolted something loose?
Old Nov 13, 2003 | 11:39 AM
juanb's Avatar
yes i did hit a bump i think.. but where do u think is a good place to start looking, i have looked at all my plugs that go to my stearing wheel and my cluster and i haven't found anything wrong,
**** I NEED TO FIX THIS ****!!!
Old Nov 13, 2003 | 11:58 AM
Steri's Avatar
Default Re: (juanb)
Maybe I'm misunderstanding you but if your remote wire is cut up and touching something you should tape it up. The remote is a signal wire that when the car is turned on sends a voltage to your deck or amp to turn it on. If you tried taping it up already then ignore me.
Modified by Blue_EJ6 at 3:09 PM 11/13/2003
Old Nov 13, 2003 | 06:17 PM
juanb's Avatar
naw man i took all that **** out including my remote wire, batterywire, ground for amp. ect.
thanks though
Old Nov 17, 2003 | 07:23 PM
juanb's Avatar
someone told me this maybe b/c i have a bad clutster, but will a bad cluster cause the turn signals to short out too.. and burn out every fuse that i put in the turn signal slot?
thanks
Ricextacy
Sep 28, 2009 10:49 AM
Auby
Jun 22, 2008 02:14 PM
mr.4door
Nov 5, 2006 05:03 PM
Kite
Oct 15, 2005 09:09 PM
turbotime
10
Mar 28, 2004 07:06 PM
