Need help on code 43
Old Sep 9, 2001 | 12:03 AM
Turbohatch's Avatar
New User
Default Need help on code 43
i just was running my car pretty hard at the track and in 3rd at 8000 it threw the code 16 fuel injectors and code 43 where is the problem??????? p.s. im running about 8 psi on a b16 with gsr injectors
Old Sep 9, 2001 | 10:49 AM
DelsolVtec18's Avatar
New User
Default Re: Need help on code 43 (Turbohatch)
I GOT A CODE 43 ON MY CAR TOO...MY FRIEND TOLD ME ITS A BAD O2 SENSOR...WITH CODE 43 YOUR CAR SHOULD BE RUNNING HELLA LEAN SO THAT MIGHT TRIGGER OFF YOUR CODE 16(BAD INJECTORS) CAUSE YOUR INJECTORS AINT PUMPING OUT ENOUGH GAS...SO JUST CHANGE YOUR O2 SENSOR FIRST AND RESET YOUR ECU AND SEE WHAT HAPPENS.
Old Sep 9, 2001 | 11:20 AM
976's Avatar
976
New User
Default Re: Need help on code 43 (DelsolVtec18)
http://www.hondaprelude.to/articles/mil_check.html
This will help with trouble shooting...
Old Sep 9, 2001 | 12:59 PM
Turbohatch's Avatar
New User
Default Re: Need help on code 43 (prsi)
yeah that might be it becuase my air to fuel guage was running completly lean
Old Sep 9, 2001 | 09:01 PM
Turbohatch's Avatar
New User
if it is not my o2 sensor then what could it be>>???
Old Sep 9, 2001 | 10:29 PM
976's Avatar
976
New User
Try getting new O2 sensors - primary or seconday - I have no idea, use the MIL code to figure what one...
Old Sep 10, 2001 | 12:44 AM
New User
If its not the o2 sensor then i have no idea...I got to find a new o2 sensor...let me change my o2 sensor first to see if this solves the problem...damn where can i find a o2 sensor at???
Old Sep 10, 2001 | 02:42 PM
976's Avatar
976
New User
Order it though a local auto parts store...
Old Sep 12, 2001 | 10:56 AM
New User
AY TURBOHATCH...IT IS THE O2 SENSOR...I JUST CHANGED MY O2 SENSOR AND NOW MY CAR IS RUNNING FINE...NO MORE CHECK LIGHT AND MY AIR/FUEL GAUGE IS READING NORMALLY AGAIN...SO JUST CHANGE YOUR O2 SENSOR AND THAT SHOULD FIX CODE 43...OH AND U DONT REALLY NEED A O2 SENSOR FROM A GSR...I USED THE 02 SENSOR FROM A 93 CIVIC...AS LONG AS THE PLUG IS THE SAME AND THE LENGTH IS LONG ENOUGH U DONT HAVE TO GET A GSR O2 SENSOR...SO IF YOU STILL HAVE YOUR OLD CIVIC MOTOR THEN JUST USE THE O2 SENSOR OFF THAT MOTOR...OR GO TO THE JUNKYARD OR http://www.oxygensensors.com/ I AM PRETTY SURE ANY O2 SENSOR FROM 93-UP CIVIC/DELSOL/INTEGRA WILL WORK
Spug
May 26, 2012 12:15 AM
crx_si-r
Feb 17, 2010 05:16 PM
Rudelude22
Sep 29, 2005 10:20 AM
s14hybrid
Nov 24, 2004 05:16 AM
tub_sephiroth
Jun 11, 2003 02:21 PM
