Need a baseline to get a motor running Fuel pressure and timing
Old Nov 8, 2003 | 04:25 PM
555R's Avatar
Default Need a baseline to get a motor running Fuel pressure and timing
its for a friends 12.5 motor, with 310cc injectors, 255liter pump,
need to get a baseline for fuel pressure and timing so we can break it in safely?
I dont want to break in that motor like I stole it
Old Nov 8, 2003 | 05:59 PM
naturelovindc2's Avatar
Default Re: Need a baseline to get a motor running Fuel pressure and timing (555R)
bump for something I was wondering myself
Old Nov 8, 2003 | 06:15 PM
555R's Avatar
no tech heads out there willing to help out
Old Nov 8, 2003 | 07:14 PM
Suprdave's Avatar
16 Degress Base and 40psi? What are you tuning it with?
Old Nov 9, 2003 | 04:36 AM
555R's Avatar
Default Re: Need a baseline to get a motor running Fuel pressure and timing (Suprdave)
at the moment its my borrowed chipped p28 skunk 2 prog
soon hondata but we want to break it in first
its a fully built 12.5 motor
Old Nov 10, 2003 | 05:31 AM
TGUNNER's Avatar
Same set up here.. But with a stock GSR computer and VAFC (untill break-in, then going to hondata) I got my FP set 42psi with the vacume line closed so at WOT is at like 50-51. I have my VAFC set at like +10 at 7000rpms and its still leaning out up top (Damn the stock computer!!). Remind you I have 310's Walbro 255. Im still in my break-in period (I have around 800 miles so far) so im being careful.. You may have better luck with your SK2 computer. Your gonna need alot of fuel up top!! Cant wait for Hondata!! Good luck, Keep us posted.
Forgot to add timing is at 15 degrees to be on the safe side with colder plugs.
Old Nov 19, 2003 | 07:14 PM
555R's Avatar
Default Re: Need a baseline to get a motor running Fuel pressure and timing (TGUNNER)
your car must be weird cos i have to run it lean up top... Jun prog in the P28
and a plus 5 in the mids for now
plugs are clean with black around the sides
and dammit im getting 22-24 mpg
but i think it has issues up top past 7k on pump gas
still working on it tho
hondata is on the way
Old Nov 19, 2003 | 07:53 PM
TwistedHatch's Avatar
for breaking something in, i'd stick like around 40 psi for fuel pressure.......and as far as the timing goes i'd start at 10 and listen for detonation or check the plugs.......if you get any detonation i'd move the fuel up 5psi at a time or you might have to retard the timing....just my 2c
92slowvic
16
Aug 27, 2005 08:06 PM
PreStaged12s
Oct 11, 2004 11:39 AM
VtecDA9
Feb 12, 2003 03:06 AM
carblegal
Sep 12, 2002 12:47 AM
