how do you know if your new brake pads are "glazed"? Carbotech Bobcats. OEM discs.
Old Nov 8, 2003 | 03:53 PM
b18crx's Avatar
Default how do you know if your new brake pads are "glazed"? Carbotech Bobcats. OEM discs.
Bought some Carbotech pads and turned the rotors. They dont feel as grabbing as would be expected. Have I not broken them in proper and what does it feel like to have glazed pads/rotors?
Old Nov 8, 2003 | 10:08 PM
CRX-RX's Avatar
Default Re: how do you know if your new brake pads are "glazed"? Carbotech Bobcats. OEM discs. (b18crx)
You need to take the pads out and see if they are glossy and smooth, if so glazed over.
Old Nov 9, 2003 | 08:30 AM
b18crx's Avatar
Default Re: how do you know if your new brake pads are "glazed"? Carbotech Bobcats. OEM discs. (CRX-RX)
what, then, needs to remedy the situation?
Old Nov 9, 2003 | 10:01 AM
mntuner2's Avatar
Light sanding to remove the glaze. Turn your rotors and disc them also. After that go easy on your brakes for a couple hundred miles. That should do the trick.
Old Nov 9, 2003 | 10:36 AM
johnzm's Avatar
Default Re: how do you know if your new brake pads are "glazed"? Carbotech Bobcats. OEM discs. (mntuner2)
hey dan, i glaze my ROTORS over about every 15k. u knwo im hard on them
u need to be easy on the pads until they are broken in, or u will be only grabbing a part of the rotor since the pad will not fully be contacting. just look on your rotors for purple/blue streaks, and if there are you need to pull it apart. i usually scrub the pad on the asphalt, easy and pain free good luck
Old Nov 9, 2003 | 10:57 PM
b18crx's Avatar
Default Re: how do you know if your new brake pads are "glazed"? Carbotech Bobcats. OEM discs. (johnzm)
i was hopeing glazed didnt imply "fuc_ed" sweet and easy enough. from what you described, they are just that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">hey dan, i glaze my ROTORS over about every 15k. u knwo im hard on them
u need to be easy on the pads until they are broken in, or u will be only grabbing a part of the rotor since the pad will not fully be contacting. just look on your rotors for purple/blue streaks, and if there are you need to pull it apart. i usually scrub the pad on the asphalt, easy and pain free good luck</TD></TR></TABLE>
Old Nov 13, 2003 | 10:43 AM
mntuner2's Avatar
Oh yeah, I forgot about the Hard Spots. These are darkish looking specks on the suface of the pad contact area. These are created by impurities in the rotor burning during excessive heat (hard braking). There usually circular, bluish/gold, glassy looking in appearence. Throw your rotors away if you see this on the rotors and get some new ones.
xanatoes
Jul 25, 2007 12:48 PM
::MYCORD::
Jul 11, 2004 03:00 AM
miksew
Mar 24, 2004 08:45 AM
