anyone using non-power brakes with the stock honda master?
just curious how it worked out and if the master bolts to the firewall where the booster once was.
thanks,
Jared
thanks,
Jared
With no brake booster you have to stand on the brakes at the end of the track. Plus it will getting some used to also. But it works fine as long as you only hook up the fronts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAMGENDAI »</TD></TR><TR><TD CLASS="quote">With no brake booster you have to stand on the brakes at the end of the track. Plus it will getting some used to also. But it works fine as long as you only hook up the fronts. </TD></TR></TABLE>
So hooking the fronts to the master only and running the rear to a staging brake would work fine? BTW, does the master bolt up or is fabrication required?
thanks,
Jared
thanks,
Jared
Are you guy's sure about this, what if you were have to brake fast to get out of the way of something, help me out here to understand.
John@M&H-Hashim's
John@M&H-Hashim's
Hi john,
You kinda dont want to slam on the brakes in a drag race car. One reason is the 70 30 rule 70% over the front wheels you could indo the car in be in a whole new world of trouble. Plus with carbon brakes they grab alot better than regular brakes so you definetley dont want the power assist becasue in a crash situation you can easily indo the car. just my opinion.
http://www.villagephotos.com/v...92052
here is a pic of my set up.
we sell these complete with the linelock on the rear brakes,strange master cylinder and mount plate complete for 299.95.
thanks
brian
sangamon valley racing
217-520-5079
thanks
brian
217-520-5079
We used to run kennys on a stock master w/o the booster. I took the master apart and had to weld a nut on the end to screw the clevis into. If you take it all apart and look at it you can see what needs to be done.
EsCo_EsCo
Dec 21, 2007 05:57 PM
Budddweiser
Oct 8, 2006 03:19 PM
Walterronny
12
Apr 16, 2006 08:01 AM
bruvaman
Jul 9, 2002 07:19 PM
on my face.
