LS/VTEC stuff
Alright here we are.
I've got my block overbored .25 and got ctr pistons .25 overbore and have eagle LS rods. Do I need to have anything special done to get the ctr pistons connected to the rods?
Anther thing about Fuel. Here is what I got a stock B16 fuel system, I was looking at some DSM Talon 450cc injectors. Some people said it would be too much for an all motor LS/VTEC system. I should be running 12.4:1 or 12.1:1 still studing. I've got a B16 head and a b18a block. Any suggestions how I do the fuel system. Here is what I think so far
DSM 450cc injectors I can get for $40 <from a friend>
AEBS Fuel Rail
aftermarket fuel pump if needed
Arospeed Regulator and gauge <already ordered>
Need some info
AEBS Fuel Rail
Need some info
Some people told me 450cc injectors in my ls/vtec would burn rings, they say that because I'll be running rich, right? would a Fpr fix that? I don't know about stock injectors on 12.4:1
OEM piston wrist pin doesn't fit eagle rod without mod.
If you use 450 injector you need some fuel control. ie, Hondata, AEM EMS, e-man...etc.
I have RC 440 on my fully build b20..i have lean it out to -50% on VAFC at idle and still getting 12.8-13.3 AFR.
Fuel pressure is set to 40psi w/o vac.
You cant run the 450s with some form of fuel control. Waaaaaay to rich.
I have tried the DSM 450's with a VAFC. I spent about an hour on the dyno. Although some guys have done it. It didnt work out well for me. I think that the correction factors were too big.
Went back to stock with a higher fuel pressure and was much better off. I have a ls/vtec ctr pistons and ctr cams.
I have a b20/vtec with 12.0:1 of comp. At the beginnig I was running 450 dsm injectors but it was a way to rich.. i try to tune with my fpr... I have video on dyno and you can easily see the black smoke coming of my exhaust.. I was runing like 18 psi on the FPR... right now i'm running Prelude injector.. and its fine..
I will say, get the DSM injector only if you have a STANDALONE to adjuste your duty cycle...
If not
Try to find Prelude injector it will be fine and you will be able to tune it a little bit..
If you want to now the right injector you need.. try this link and you will see what you need... i think a b20/vtec it's 310cc with a good pressure(40psi)
If not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupeMT »</TD></TR><TR><TD CLASS="quote">i believe all bseries injectors are the same 270cc's</TD></TR></TABLE>
They are all 240 cc not 270cc
-sander
-sander
TylerLorenz
Oct 18, 2010 05:57 PM
