how much horsepower
Old Nov 7, 2003 | 10:05 PM
1hotvtec's Avatar
Default how much horsepower
I am revamping a b18a with arias pistons eagle rods skunk2 cams and valve and basic bolt ons. What type of power output can I except out of this setup? And don't tell me to search because I have and I am just looking for some one out there to shout out an estimate or number. I think that with my new b16a head and all my new part I will probably have about 215. I am using a comptech intake system, apexi header, bomz high flow cat, jic st cat back, and my other various parts up top. Tell me what you think?
Old Nov 7, 2003 | 10:10 PM
mel_2kgsr's Avatar
Default Re: how much horsepower (SPOONCIVIC_97)
what's the compression on the pistons? and what stage skunk2 cams?...
Old Nov 7, 2003 | 10:13 PM
Eviloliv3's Avatar
id say about 140-160 without tuning, and then after tuning, about 170-185 or so. no way to tell other than getting on a dyno
Old Nov 7, 2003 | 10:51 PM
rtype11's Avatar
youll eventually get 185 at the wheel tuned right assuming your compression is 10.5 or higher.
Old Nov 8, 2003 | 09:40 AM
1hotvtec's Avatar
well they say that the skunk 2 cams stage 2 give you 22 hp. The pistons were going to be low compression because I am going to be running a good turbo setup on the car. Probably turbonetics with spearco intercooler. Does this help for a estimate.
Old Nov 8, 2003 | 11:43 AM
oMek's Avatar
Old Nov 8, 2003 | 12:06 PM
Downey's Avatar
i dont think skunk2 stage 2's will work very well with a turbo setup. stay with some GSR cams. skunk cams are designed to work with high compression NA engines
Old Nov 8, 2003 | 12:29 PM
reverie's Avatar
Default Re: how much horsepower (oMekoneDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
You were itching to use that picture, huh? So people can acknowledge your clever humor?
Moron.
Old Nov 8, 2003 | 01:18 PM
oMek's Avatar
Default Re: how much horsepower (reverie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reverie &raquo;</TD></TR><TR><TD CLASS="quote">
Moron.</TD></TR></TABLE>
comedy hour
Old Nov 8, 2003 | 04:37 PM
neo1z's Avatar
Default Re: how much horsepower (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">youll eventually get 185 at the wheel tuned right assuming your compression is 10.5 or higher.</TD></TR></TABLE>
Stock Compression - 188.6 whp on Skunk2 Stage 1's, on VAFC tuning only.
185 whp is a bit low IMO.
Also - If youre running Skunk2 cams, get high-comp pistons. If youre going turbo, do not run Skunk2 cams.
Old Nov 8, 2003 | 04:43 PM
jdmotorsports's Avatar
Default Re: how much horsepower (neo1z)
n/m
Old Nov 8, 2003 | 06:18 PM
Bubb Rubb's Avatar
Skunk 2 cams + Turbo = Bad times.
Skunk 2 cams are pretty much for people beefing up NA motors.
egsir2
15
Jan 12, 2007 02:11 PM
Red05TypeS
Dec 21, 2005 07:14 PM
majormaster01
11
Feb 4, 2005 10:31 AM
J2turbo21
25
Jul 29, 2004 02:49 PM
dabomb
Mar 24, 2003 03:31 PM
