code 17 VSS
Old Nov 7, 2003 | 07:27 PM
Lo-Buck EF's Avatar
Default code 17 VSS
my spedo worked just fine on sunday before my engine went south. fast fwd to today. once we got everything working right i noticed my spedo doesnt work. then the ecu throws a code for it (17). my guess is i dont have it in the trans correctly or something. is there a special way the unit with the gear goes into the trans? is there a special way the cable goes into that unit?
-spenc
Old Nov 7, 2003 | 07:32 PM
91civicDXdude's Avatar
put the cable in, put the clip in. its that simple.
Old Nov 7, 2003 | 07:42 PM
Lo-Buck EF's Avatar
Default Re: (91civicDXdude)
aah, what clip?
Old Nov 7, 2003 | 08:42 PM
89civicdx's Avatar
Default Re: (Lo-Buck EF)
There is a clip that holds the cable in the tranny without it the cable can bounce up and not engage....is a small clip and its easy to loose.
If you can find a diagram of the tranny or speedo cable you should see it on there.
Old Nov 8, 2003 | 03:32 AM
Lo-Buck EF's Avatar
Default Re: (89civicdx)
Old Nov 8, 2003 | 08:23 AM
Lo-Buck EF's Avatar
Default Re: code 17 VSS (Lo-Buck EF)
stil no workie. it used to work w/o the clip too, so i dont thing my problem stems from there. and since its cable driven, there is very little to go bad. everything on the trans end seems to be ok. im gonna try my spedo gear from my old 4speed. if that doesnt work ill take a look at the back of the cluster. maybe durring the swap we may have pulled it out of the cluster.
-spenc..........just wants to see if he can hit 100 @lrp on monday
Old Nov 8, 2003 | 08:34 AM
Lucifer6i9's Avatar
dam speed cable i hate them !!! i had to fix one on this hatch and i thought it was going to be a walk in tha park yeah ok i change the cable and make sure its clipped in and than checked tha back of tha cluster. everything's in running good i drive it for ohhh 20 min no light and tha cables working but than all of a sudden check engine and its tha focking speed cable sensor. but i didnt get it because it was working still.
Old Nov 8, 2003 | 10:15 AM
89civicdx's Avatar
Default Re: code 17 VSS (Lucifer6i9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">maybe durring the swap we may have pulled it out of the cluster</TD></TR></TABLE>
check that first...that happens quite often...forgot to say that.
Old Nov 8, 2003 | 01:52 PM
Lo-Buck EF's Avatar
Default Re: code 17 VSS (89civicdx)
pulled it out of the cluster allright. pulled it out of the metal fitting too. took some doing to get the cable housing back into the metal fitting but all is well.
-spenc..........who never thought 10mph on the speedo would look so good
Old Nov 8, 2003 | 03:37 PM
MestizoRacer310's Avatar
That's what happened on mine..but it was like that when I bought it. The internal piece that rotates was pushed flush with the outer "sheath" and didn't engage the gear inside the tach/speedo. Also the metal collar fitting at the end (the end that goes inside the trans) was pulled off.....therefore pulling the internal piece. I pushed it back on as far as it would go and crimped it down again, but the tach "jumps" or looks like it's sticking. I need a new cable, but it works for now and it'll have to do. Got some other stuff that needs fixing to get it back to 100%.
Old Nov 8, 2003 | 04:33 PM
JDMHatch101's Avatar
im throwing a code 17 also, ive alredy checked the tranny out, and the back of the cluster with no results any help please?
Old Nov 8, 2003 | 05:21 PM
fourthgenhatchB17's Avatar
Default Re: (JDMHatch101)
IF everything u checked out is OK and all hooked up properly, then the speedo cable itself has snapped. To check this, take the cable out of the speedo gear in the tranny, and pull on the cable itself thats inside. If its snapped, then part of the cable should come out completely. I just fixed this exact problem on my friends hatch and his speedo cable was in 2 pieces.
Old Nov 8, 2003 | 06:07 PM
the only problem with that is wouldnt my speedo stop workin? becauce mine still works fine.
Old Nov 10, 2003 | 11:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatch101 &raquo;</TD></TR><TR><TD CLASS="quote">the only problem with that is wouldnt my speedo stop workin? becauce mine still works fine. </TD></TR></TABLE>
Cluster may be defective...i believe the VSS for our cars is located in the cluster itself. On later cars it is not.
dusterbd13
Oct 19, 2009 06:47 PM
brian349
Oct 26, 2005 04:59 PM
1SIKCRX
Jul 14, 2004 10:52 PM
rasta420
Jul 7, 2002 07:50 PM
W0oT
Feb 9, 2002 03:17 AM
