Is my 2nd fan working?
Old Sep 8, 2001 | 03:07 PM
976's Avatar
976
New User
Default Is my 2nd fan working?
I have the regular dual fan behind radiator. After my car has been driven for awhile, and I turn it off the fan comes on. Of course. Anyway, I noticed that at no point does my second fan come on. My temp never goes over normal operating temp, but for safety I want the second fan working as well. How can I check to make sure it is still running properly. Thanks.
Old Sep 8, 2001 | 10:46 PM
digitalspice's Avatar
Banned
Default Re: Is my 2nd fan working? (prsi)
One of the fans is the radiator fan and the other is the condenser fan. Try turning your ac on and see if it comes on, not sure if its always on when the ac is on or only sumtimes.
Old Sep 8, 2001 | 11:27 PM
976's Avatar
976
New User
Default Re: Is my 2nd fan working? (digitalspice)
Yeah, after I posted I got to thinking about that. Thanks, you cleared it up. Would it be a good idea to convert both fans to work at the same time, I rarely use AC because of our marie northwest climate - seattle
Old Sep 9, 2001 | 09:40 AM
fixhondas's Avatar
Both fans are supposed to work at the same time- turning the A/C on will show you which one is not working- then you can troubleshoot it.
Old Sep 9, 2001 | 05:13 PM
Mr. Choi's Avatar
New User
Default Re: Is my 2nd fan working? (fixhondas)
not on all cars, im not sure about his 1990 prelude since i dont have one but my moms civic has one fan for the radiator and one for the AC condensor. my Camry has two fans for the radiator and the condensor is in front of the radiator. so on the camry both fan would come one when the engine needs cooling or the ac is on. this may be the case for the prelude, im not sure cause i dont have one. the point is that both fan dont usually turn on the sametime on all cars, it all depends on how it was made and how it was supposed to function.
Old Sep 9, 2001 | 07:57 PM
fixhondas's Avatar
Default Re: Is my 2nd fan working? (Chois i-VTEC)
I was speaking of hondas with full width radiators and condensers. The reply was for a 90 prelude- NOT ALL CARS.
Old Sep 9, 2001 | 08:22 PM
Spooch69's Avatar
i had the same problem with my kord. One of the cenors to the fan is not working right so you have to get it replaced.
imbest123
Oct 24, 2011 06:14 AM
Protoss
Mar 17, 2006 01:09 PM
B18EG6
Aug 23, 2005 10:41 PM
ROOROWNS
Jun 6, 2005 05:44 PM
