Koni Yellows/Eiback pro kit
Anybody know how much of a drop this set up will give me, and also if I will need a camber kit? I just ordered this set-up from a member here. Anyone else running this set-up? How do you like it?
Thats a very popular combo here. Yes it will be 1.3 drop, but rmemeber eicbach doesnt compensate for the larger wheel wells of the integra so the front will appear higher. Solution use your konis and drop it using the lowest perch, not sure how much exactly it will lower it more, but it shoudl still be a very mild drop, that looks good, and handles well
After 1.5 is where camber starts to become a problem. Bump for a local
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitto003 »</TD></TR><TR><TD CLASS="quote">Anybody know how much of a drop this set up will give me, and also if I will need a camber kit? I just ordered this set-up from a member here. Anyone else running this set-up? How do you like it?</TD></TR></TABLE>
i did research on that combo and came up with one conclusion. Eibach might give you an uneven drop. ur rear drop will not be even. i know it's now true for every car, but i've seen too many to believe it. so my solution? H&R oe sport with kyb agx. H&R is a lot cheaper, and gives you a even drop all around.
Yah H&R gives a better looking drop and they are 1.5 in fron and 1.75 in back, most users say they think its a little more than that, but the drop is nice. The catch is most likely you will need a camber kit with the h&R's. It sup to you if you want aconservative drop then go with the eibach/prokit, if your looking into a little more aggressive drop the h&r/koni is a good choice.
Well that sucks. I was hopeing that it would be atleast 1.5inch drop. Do you think this set-up will look ok with 16inch rota c8's? I mean do you think the drop will look ok with not too much wheel well gap?
George H
Jun 29, 2001 10:32 PM
George H
Jun 14, 2001 04:21 PM
