Q for people using DSM manifold.
Old Nov 7, 2003 | 10:57 AM
thehatchninja's Avatar
Default Q for people using DSM manifold.
I was wondering what clearance issues there are with this manifold? Is it possible to retain A/C? what about the front mount? Thanks in advance
Old Nov 8, 2003 | 12:51 PM
Default Re: Q for people using DSM manifold. (thehatchninja)
hello.....is anyone running this manifold? i forgot...my friend has a 93 ex accord, and we're researching
Old Nov 8, 2003 | 01:31 PM
Eurorider1's Avatar
hey bud i have 92ex turbo 14b dsm used mani but u have to fix it so the holes match cuz not all of the match up no biggy on that one. ac on the other hand when i did my ur pretty much screwed on that unless u build something to tilt ur mani up. also doing that u need a peice of advice on the turbo'n u got a f22a6 most likely and what ull have to do u use dsm mani and have turbo on it is one u have to take off front motor mount and two u have to have to cut into the block kinda nothing big cuz that is where the turbo will sit. the intercooler i didnt have a problem with cuz the out flow is on top so i had tube bent around and it ran from left side of motor to right under the head light on the drivers side into the front bumper. and then over where the stock intake sat i cut into the wall by where the battery sat and ran piping up to my tb and just had stock dsm bov. i remounted battery in trunk not hard at all just time consuming hey if u want to do that i got 2.5 exhaust piping that is custom made for accord dsm 14b. for like 150 its not no cats all u need is a muffler on the end and its good to go i got pics if uw ant all if u need me send email to taz619@aol.com and thats my email just say hey wondering about 14b accord on the heading
Old Nov 8, 2003 | 02:33 PM
D21X's Avatar
Default Re: Q for people using DSM manifold. (EURORIDER11)
Eurorider11, how fast was your car with this kit? what was your setup to concerning fuel management, IC, turbo, piping, etc. thanks!!!
Old Nov 8, 2003 | 04:34 PM
Eurorider1's Avatar
Default Re: Q for people using DSM manifold. (D21X)
on stock internals i was running 8psi which i think is like 240hp not for sure i maxed it out at 13psi at like 270 to the crank.
fuel management fmu holly, dsm blue tip injectors, and rewired a dsm fuel pump in where mine was. intercooler piping i made from exhaust pipe manderal bent, intercooler was a spearco cool 2.5in let i beleive. anwayz it ran like 14's or even high 13's at max boost. stock interals can hold a max of 8psi dont run anything past that beleive me its not good (personal experience). but wtih all the fuel and everything iw as running rich so i could have done some stuff probably and got it running faster but i blew up the motor over reving it
o well anywazy i got all that stuff the turbo and all if u guys want any pics just hit me up on aol and ills end ya pics of it.
Old Nov 8, 2003 | 05:56 PM
v4lu3s's Avatar
RTFM
how are you calculating 8psi is 240 hp? were you on a dyno at all with it?
Old Nov 9, 2003 | 01:47 PM
Eurorider1's Avatar
Default Re: (v4lu3s)
oh my bad it was 220 at 8psi. 13psi= 270hp was dynoed but i did some mods to ecu how much fuel i was using and other some other small things.
Old Nov 9, 2003 | 03:21 PM
EGPrelude's Avatar
hey eurorider,
that sounded like a nice car, send me some pics
chyneezb0y@aol.com
Old Nov 10, 2003 | 06:44 PM
Eurorider1's Avatar
Default Re: (EGPrelude)
hey lude if i can find my buddy that has my pics ill send ya some but i had my turbo set up for about a month i should have got all my before and after pics but ill see if i cant get those pics for ya
Old Nov 11, 2003 | 09:07 AM
Default Re: (EURORIDER11)
wo you have to remove the a/c and the front mount?
96ej8MR
Sep 3, 2007 06:43 PM
silverboost
Oct 31, 2006 05:24 PM
wrEcKed_LX
Mar 20, 2006 12:36 PM
SimonsTeg
Jul 7, 2002 03:19 PM
