Air Filter?
Does Air filter of Accord or any car affect the horse power of the car??? if it does what is the recommended Air filter for Accord 98 and above.... are there any other filters which could be used other than Honda mde filters to improve power??/ need feedback
Thanks
Thanks
it does affect horsepower because horsepower depends upon how much air you have going through that engine. so more air will equal more horsepower (roughly, in most cases). K&N is def the brand i would go for
I am guessing you still have the stock oem air box.
you can go wrong with oem honda replacement, factory
K&n is good but there's couple things i want you to know before buying it
1)they are reuseable/rewashable(need to get addition K&N recharge kit, which clean and reoil the filter element)
pro: you can clean your filter when you feel like it, keep it clean all the time=better gas mileage
con: the dxmn thing cost like 40 buck, the recharge kit is 13buck plus tax in kragen. I highly recommend to change the filter once a year, yes you can recharge it but it need to be replace. Some car equiped with MAF can get fouled up with K&N's oil, lucky honda have map instead.
APEX'i filter is the best one out there, better filtering than K&N/AEM filter and with the same air flow rating as HKS' super mega flow filter.
too bad they are 70 buck each, can't wash/clean
JohnQPublic
Jul 24, 2007 07:33 PM
