Liquid Filled Gauges
Old Nov 7, 2003 | 09:42 AM
Muckman's Avatar
Moderator in Chief
Default Liquid Filled Gauges
What kind of liquid is used in liquid filled gauges?
Its not water is it? Because that would be bad in the winter.
What type is the B&M Fuel gauge? It doesnt say on their website and Ive searched.
Old Nov 7, 2003 | 12:30 PM
ionic_slim's Avatar
Default Re: Liquid Filled Gauges (Muckman)
I think the B&M is mechanical...can anyone give us some examples of a liquid type gauge?
Old Nov 7, 2003 | 12:50 PM
Muckman's Avatar
Moderator in Chief
Default Re: Liquid Filled Gauges (tazmoe)
Summit makes a liquid filled gauge. I dont know of any others.
I assume liquid filled gauges are better? Why?
Old Nov 7, 2003 | 12:54 PM
JimBlake's Avatar
Liquid-filled gauges are mechanical. There's a sealed fluid inside the gauge, and usually inside the tubing leading over to the process being measured. Then there's a seal diaphragm to keep the seal fluid from leaking out & mixing with your engine oil or whatever.
Usually the seal fluid is some kind of oil. I didn't know automotive gauges were available like that. I've only seen industrial process-measurement instruments like that...
Maybe what B&M really means is that their gauge is intended to be compatible with engine oil being inside the gauge itself.
HAHAHA - I just saw what Muckman posted. Now I get it... They probably do that do dampen any wild vibrating motion of the needle.
integral94
Jan 28, 2007 12:16 AM
romoracing
May 28, 2006 07:54 AM
teddy_dc2
Mar 29, 2006 06:43 PM
JM Performance
Sep 18, 2004 01:02 PM
teg92
Apr 24, 2003 10:40 PM
