Anyone with B18C motors in a Rex
Old Nov 7, 2003 | 08:43 AM
Yell88CRXsi's Avatar
Default Anyone with B18C motors in a Rex
I am looking for some experience people have had stuffing a B18C+ swap in a CRX.
The main info that I need would be, can you do it with the stock hood? Not a CF hood, or a JDM hood. I guessing that about everyone who has a B18C swap is using Hasport mounts.
I have Place Racing, and my B16 just barely clears the hood without hitting, so the taller B18C is definitely out of the question.
Old Nov 7, 2003 | 08:52 AM
1st-hybrid's Avatar
Default Re: Anyone with B18C motors in a Rex (Yell88CRXsi)
I have HCP mounts and a stock hood. Just a little trimming on the bottom
Old Nov 7, 2003 | 08:57 AM
IntegraXSi's Avatar
There are issues with the place kit becuse it sits the b16 higher than HAsport and HCP.. the B18C1 is 8mm taller
Old Nov 7, 2003 | 10:37 AM
manson's Avatar
Default Re: (IntegraXSi)
i have a b16 with hasport mounts and a vis carbon fiber hood. i still had to trim the hood so it wouldn't rub.
Old Nov 7, 2003 | 11:31 AM
15psi of fun's Avatar
Default Re: (mansonclubpuir)
Yes it hits I went from b16 to b18c and it rubs I have Place Racing mounts.
Old Nov 11, 2003 | 05:11 AM
Turbo Laser's Avatar
Default Re: (EFrollingout)
I don't see that much of an improvement going from a b16 to a b18c1 swap if you just paid for the b16 swap not too long ago. The power increase isn't worth the cash over the b16. I'd sooner install a turbo kit or build an engine with that $. Just my 2 cents......
Old Nov 11, 2003 | 05:16 AM
FULL-RACE EP3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yell88CRXsi &raquo;</TD></TR><TR><TD CLASS="quote">I have Place Racing, and my B16 just barely clears the hood without hitting, so the taller B18C is definitely out of the question.</TD></TR></TABLE>
wrong, i have Place racing mounts and a carbon hood and it has just the SLIGHTEST bit of rub with my b18c1.
Old Nov 11, 2003 | 10:37 AM
red civic standard's Avatar
Default Re: Anyone with B18C motors in a Rex (Pooptooth)
i have a b18c and HCP mounts with stock hood and NO clearance issues
Old Nov 11, 2003 | 03:29 PM
HandCommand's Avatar
I've done 2 GSR's into CRXs and my very own JDM Type R into my CRX HF.
On one customer's CRX with the old school HaSport mounts (non-billet) I only had to cut out the some of the "webbing" underneath the hood. That cleared fine.
On the other customer's CRX with GSR using the Newer Billet style Hasport mounts, the engine sits higher and tilted differently. I also had to cut out the "webbing" also, but the "Acorn" nuts used to hold the spark plug cover comes in contact with the hood. ( just the front two)
On my CRX HF with ITR motor, Im using the latest Hasport HYDRO EF kit, I also had to cut out some of the underhood "webbing" to clear the taller ITR engine. I also had to modify the HECK out of the front OEM crossmember to clear the JDM 4 into 1 header!! ( but that's another story)
If you are using the stock "sea-shell" GSR intake manifold in CRX or Civic, your TPS sensor is going to be pretty dang close to the fuel line coming from the firewall. Its a tight fit with that stock manifold.
If you have the dough, ditch that stock GSR manifold for a Skunk2.
poor-boy-eg
Mar 11, 2019 06:28 PM
ninepointfive
51
Oct 11, 2007 09:53 AM
Fishcat37
29
Feb 1, 2006 12:14 PM
Fishcat37
Oct 11, 2003 10:51 PM
Outkast_CL9
15
Sep 20, 2003 11:13 AM
