rear dics brake coversion troble-need help
Old Nov 7, 2003 | 06:24 AM
twerker08's Avatar
Default rear dics brake coversion troble-need help
I have a 93 civic hb,and I decided to put rear brakes from an acura on th rear.The swap went fine .Bleeded the brakes got the air out,pedal felt good.Took the car for a drive and there is no brakes.Someone told me that I should of replaced the brake booster with the acura one,is this true.If it is any help I have the front brakes from the acura on the car to.please any help would be great.
Old Nov 7, 2003 | 06:53 AM
EF_LSVtec's Avatar
Default Re: rear dics brake coversion troble-need help (twerker08)
Replacing the brake booster, proportioning valve are an option but not necessary...some things wrong if you lost your brakes. btw, you might want to post on the EG forum.
Old Nov 7, 2003 | 07:01 AM
civicsir.com's Avatar
i did the same, and have the same ff/rr brake setup as yours... siR conversion. i didn'tn replace it with a bigger one, just bought a new one, and the brakes have been fine for more than 2 years now.
maybe is a good time to go and buy a new one!!!!!!!
good luck!
BTW, which e-brake cable did u use??
levi506
Suspension & Brakes
Jul 31, 2012 11:19 AM
rexfan
36
Aug 31, 2009 11:43 AM
ekx4
Jun 29, 2004 06:35 PM
mickey513
Oct 2, 2003 04:35 AM
ACURACY_VTEC
Aug 29, 2002 03:12 PM
