Is this true about resurfacing?
Old Nov 7, 2003 | 04:56 AM
SupaFly_Honda's Avatar
Default Is this true about resurfacing?
when you resurface your head and block, does it effect the compression of the motor?
Old Nov 7, 2003 | 05:12 AM
eghonda's Avatar
Default Re: Is this true about resurfacing? (SupaFly_Honda)
removing any material from the mating ends of the head and block will up your CR. resurfacing however would have minimal effects.
if you were to mill the head then you could bump it up a bit. keep in mind that once you mill you can't go back and that in some cases you will need new cam gears to remedy the shorter height of the head/block
Old Nov 8, 2003 | 10:54 PM
aeolus's Avatar
Default Re: Is this true about resurfacing? (eghonda)
You only need adjustable cam gears because the timing gets retarted a little.You could still use stock ones,but your cam or cams are gonna be retarded a little depending on how much you have shaved off the head or block.
Old Nov 9, 2003 | 06:52 AM
Big Teggie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupaFly_Honda &raquo;</TD></TR><TR><TD CLASS="quote">when you resurface your head and block, does it effect the compression of the motor? </TD></TR></TABLE>
How much did you take off?
salman
13
Jan 25, 2008 04:51 PM
SlammedCD7
Jul 17, 2005 11:36 PM
omgwtfhaxnub
Jun 2, 2005 09:23 AM
93H22ACX
Jun 14, 2004 05:27 AM
