Problem baked my noodle......MISTABONE...or tranny GURU plz
ok, I just got a dohc zc installed in my civic, I also used the ZC tranny with ZC intermediate shaft, and Integra axles (91 integra non abs)
problem im having is, the passenger side axle is wobbling right where it inserts into the transfer case, it moves maybe 1/8"-1/4" in a circle while the car is running, and if i goto lift move the inner joint around it does have play inside the tranny..
Ok, so Im gussing the problem is the bearing,
I need a manual or pictures or walkthrough about pulling this apart, and while im at it is it worth putting in a SI final drive? I already have all the parts ready to go, but im affraid of splitting the tranny and not being able to put it back together correctly..
I had that exact same problem on my LS tranny....turned out to be the thrust washers inside the Differential were worn out. So what you need to do is pull the tranny, crack it appart and pull/rebuild the Differential, and you should be set.
like previous guy said
it more likely is a worn washers (wich a doubt)
o ru already have a differential with a very worn out diff pin
and at any sign of stress it will be prone to brak and dedstroy tranny
i say open it and rebuild it or get a quaife
