Full harness swap? (keep obd1 in a 98 ek?)
I am putting my usdm b16 into a 98 EK and want to keep obd1- I was thinking of just swapping the entire harness as well! I have a totaled 93' cx as a donor-
So anyone done this? What does it consist of?
Thanks and i have searched, if you have links that would help also! (or suggestions on searching)
You're going to have to modify your existing engine harness to work with the obd 1 b16. That basically consists of the injectors and the distributor plug. There are going to be a couple plugs on the harness that won't have a home on the motor due to the differing obd.s
Get an ecu harness converter and you should be cool if you want to run OBD 1
this is what you need to get an obd1 sir2 into an obd2 ek
http://www.hondaswap.com/swap/viewer.php?id=47
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XratedSi »</TD></TR><TR><TD CLASS="quote">I now have a 00' SI harness and an obdIIb-obd1 harness....but there are 2 damn plugs on the drivers side of my EK and only one plug on my 00' SI harness....HELP!!</TD></TR></TABLE>
You're still doing it wrong. That Si harness is useless. You need to modify your 96-98 engine harness.
Then you need to get an regular dx or ex harness.
Thats the only way it's going to work. I'm sure you can use the auto harness, but I'm not sure what you have to modify.
xxstreetracer605
Jul 9, 2011 05:23 PM
h22_crx
Aug 10, 2007 10:10 PM
deluzracerx
Jun 18, 2005 07:51 AM
Capt. Jimbo McSubipants
Mar 19, 2005 11:36 AM
