SOHC ZEX cam question???
Old Nov 6, 2003 | 06:49 PM
japspecjohn's Avatar
Default SOHC ZEX cam question???
Will the zex sohc cams work on a d15b?
thanks
John
Old Nov 6, 2003 | 08:03 PM
biassj's Avatar
Default Re: SOHC ZEX cam question??? (japspecjohn)
Yes use the Z6(same head), I heard the JDM D15b is pretty agressive already(don't know specs) so you won't see much gains.
Old Nov 7, 2003 | 02:38 AM
Default Re: SOHC ZEX cam question??? (biassj)
I heard the same but dont know the specs either but they said it was same as the lower model cam There is two they sell for the z6 ones, suppsoedly 12hp and ones like 14hp doubt that much horse but anything helps.
Old Nov 7, 2003 | 05:01 AM
SOHC_MShue's Avatar
i've heard the stage 2 is much better than the stage 1. I wouldn't even bother with the stage 1. Get the stage 2 with part number 59300
Old Nov 7, 2003 | 06:43 AM
blackeg's Avatar
Default Re: SOHC ZEX cam question??? (SOHC_MShue)
definately get the 59300- the other one is barely more agressive than stock
Old Nov 7, 2003 | 07:46 AM
eg6ajk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">Will the zex sohc cams work on a d15b?
thanks
John</TD></TR></TABLE>
yes it does work. timing will need adjustment by about 5degrees either way (will depend on how you install the timing belt) this will be due block height and cam timing.
when buying go with the 59300 or even crower stage 3 otherwise you will not see any improvements. I used to run the 59300 in my d15b improvements past 5.5k rpm can only be noticed.
improvements with 3-5whp can only be noticed don't think you'll see more then that.
http://www.hadamotorsport.com/...x.htm
Old Nov 7, 2003 | 10:12 AM
SOHC_MShue's Avatar
Default Re: SOHC ZEX cam question??? (eg6ajk)
do you think that you only gained 3-5whp because the stock cam is already an agressive cam in the d15?
88civichbz6
Dec 3, 2004 03:41 PM
B18cteg
Jun 13, 2003 06:16 AM
ranger4
Aug 23, 2002 03:58 PM
Lookincrazy
May 8, 2002 10:25 AM
hondriv
Feb 25, 2002 10:33 AM
