ACT Clutches...which disc/presureplate combos are you using?
Old Sep 8, 2001 | 08:51 AM
TheShocker's Avatar
Default ACT Clutches...which disc/presureplate combos are you using?
If anyone here uses the ACT clutch which pressure plate and disc are you using and what are your impressions of them?
From Advancedclutch.com:
Pressure Plate Choices:
HD - ACT Heavy Duty Pressure Plate
XT - ACT Xtreme Pressure Plate
XX - ACT MaXX Xtreme Pressure Plate
Disc Choices:
00 - Stock Street Disc
MM - ACT Modified Street Disc
SS - ACT Performance Organic Street Disc
R4 - ACT 4-Pad Race Disc
R6 - ACT 6-Pad Race Disc
-Seth
Old Sep 8, 2001 | 09:06 AM
dustin's Avatar
Default Re: ACT Clutches...which disc/presureplate combos are you using? (miac1)
I think my CRX has the XTSS setup.
Old Sep 8, 2001 | 10:46 AM
BoostedED9's Avatar
im using the HD00 setup, it works great, if you are gona have high hp car go with a better disc and a xt or XX plate, im sure you wont slip for anything.....
Old Sep 8, 2001 | 11:47 AM
TheShocker's Avatar
Default Re: ACT Clutches...which disc/presureplate combos are you using? (ED9Hybrid)
Yea, I was thinking XTSS...the ZC will be running 15 PSI (T-25) and wil be road-raced so I need a clutch that grabs well and will hold-up to high temps. All my friends with DSMs have the ACT and it rules. I have a Centerforce stage II right now (got it with my motor) and it's only a little bit better than stock and dont think it's up to the task.
-Seth
Old Sep 8, 2001 | 01:17 PM
Stinkalope's Avatar
New User
I have heard that the xt is a little heavy for a street (every day driver) car. I have been told that the set up is a hdss, it has the best of both worlds. More grip without the pedal pressure and the ss also has great durability. For a road racing zc turbo though that set sounds like it would be perfect.... go for it.
Clerique
Aug 12, 2009 05:52 AM
StreetwizeRacin2
11
Mar 30, 2004 03:53 PM
spectunedphil
Jul 10, 2002 08:31 AM
SystemGSR
Aug 25, 2001 02:06 PM
