Why Does Aftermarket Headers Make You Run Lean?
Old Nov 6, 2003 | 01:58 PM
lazy bum shaughn's Avatar
Default Why Does Aftermarket Headers Make You Run Lean?
Can someone explain this?
I would think it would be a better mixture because the exhaust flow velocity is increased.
Old Nov 6, 2003 | 06:12 PM
StorminMatt's Avatar
Default Re: Why Does Aftermarket Headers Make You Run Lean? (lazy bum shaughn)
Aftermarket headers make you run lean because by improving scavenging, they allow more air to be ingested by the motor. But since the speed-density metering system on Hondas is not able to compensate for this too well, not much (if any) additional fuel is injected to compensate. This causes a lean condition.
catfx
Nov 16, 2014 09:26 AM
K7-1Ktrevor
Jan 13, 2009 12:31 PM
tkHBseries
Feb 24, 2004 07:49 AM
HotWheelz
Nov 7, 2003 02:34 PM
