RC injector HELP!!!
Old Nov 6, 2003 | 12:09 PM
MTP04's Avatar
Default RC injector HELP!!!
I am trying to install RC 310 inejectors into my ITR motor but I am not sure if I have to order RC spacers/graumet or can use the fatory spacers/graumet.
I did a search and I cant really find what im looking for. Could someone help me on this PLEASE!
If I can use the factory ones, how do I make them work?
Old Nov 6, 2003 | 01:22 PM
SamC's Avatar
Default Re: RC injector HELP!!! (Falcon)
not sure..but why not call RC to find out?
Old Nov 6, 2003 | 03:15 PM
MTP04's Avatar
Default Re: RC injector HELP!!! (SamC)
I actually did call RC earlier but I dont think the guy that i was talking to knew what he was talking about, he told me that they are the same and that i can use the factory ones.
Is there anyone that has run in the same problem? I am sure lots of people are running RC injectors.
Old Nov 6, 2003 | 03:44 PM
Misfit's Avatar
I will be installing mine tomarrrow night. I guess i will find out.
Old Nov 6, 2003 | 03:54 PM
MTP04's Avatar
Default Re: RC injector HELP!!! (MISFIT)
Post back when your done and let me know how it went.
Are you using RC or facotry seals/gromet?
Old Nov 7, 2003 | 11:34 AM
sgT's Avatar
sgT
use the grommets that come with the RC injectors.
Old Nov 7, 2003 | 11:59 AM
Jon D's Avatar
are you talking spacers or seals...........i know that the seals out of your old ones will not work with your new injectors..At least i dont think they will. It wont be hard to figure out though. Theyll either fit great or they wont.
Old Nov 7, 2003 | 12:09 PM
MTP04's Avatar
Default Re: RC injector HELP!!! (jh4dc23spoon and sgT)
sgT, I never got the seals with my RC injectors. I bought them used.
jh4dc23spoon, some people call them spacers and some call them seals but its what is fitted between the manifold (not the feul rail) and the bottom of the injector.
Old Nov 7, 2003 | 01:22 PM
Rob Dizzle's Avatar
if you use the oem grommets between the intake manifold and injector, you will need to shave some material off the inside.
i used a dremel with a small sanding tool, and just kept taking material off till it fit right into the intake manifold injector bungs.
you want to make sure it seals the air though
Old Nov 8, 2003 | 06:58 AM
MTP04's Avatar
Default Re: RC injector HELP!!! (Bob-DC2)
Thanks Bob-DC2, i'll give that a try.
Ch3mik
Jun 16, 2006 12:21 PM
b18civicguy
Dec 13, 2005 10:15 AM
carbonDelSol
Oct 22, 2004 11:11 AM
avex
Mar 10, 2003 10:36 PM
LiLOtaku
Feb 22, 2003 10:36 AM
