Help on H22 swap into 6th Gen LX Auto
Old Nov 6, 2003 | 08:20 AM
FSTASNTZ's Avatar
Default Help on H22 swap into 6th Gen LX Auto
I got the car with the motor and manual tranny in, yes, auto to manual. It is a 1999 Accord LX with an OBD1 H22 swap, manual tranny conversion, OBD1 P13 ECU and OBD2-OBD1 conversion harness. Got it running and what not, but has no speedometer and throws a code 41 (primary 02 sensor heater). Any pointers?
Jason
Old Nov 7, 2003 | 06:03 AM
FSTASNTZ's Avatar
Default Re: Help on H22 swap into 6th Gen LX Auto (FSTASNTZ)
No one has a clue?
Jason
Old Nov 7, 2003 | 07:18 AM
v4lu3s's Avatar
RTFM
if you have non workign speedomoter your vss is either not hooked up, not working, or has broken wiring.
Old Nov 8, 2003 | 08:10 AM
-Bionic-'s Avatar
Former Sponsor
no speedomoter = no vtec
Old Nov 9, 2003 | 08:25 AM
yun_cheezie's Avatar
as far as the ck eng lite/code, which O2 sensor wiring did you use? there's one on the manifold and the other is at the catalytic conv. if you're using the O2 wiring from the cat for your source, that's where your problem is. use the wiring of the manifold that runs under the disributor. if that doesn't work, make sure your O2 sensor is good, and if all else fails check your wiring.
the speedo prob is either the vss itself or wiring. swap it out with a known good vss to narrow it down.
Old Nov 9, 2003 | 09:04 PM
FSTASNTZ's Avatar
Default Re: Help on H22 swap into 6th Gen LX Auto (yun_cheezie)
I used the Primary 02, the front one. Have a new sensor in there too. I have the harness pulled out again, and am going to check for broken wires with the digital voltmeter, that is my last idea...
Jason
Old Nov 11, 2003 | 05:04 PM
FSTASNTZ's Avatar
Got the 02 sensor problem fixed. Turns out on the OBD1 P13, the heater circuit gets its power from the coolant sensor circuit. So, I just tapped into it, and bingo, no more code...
Now for the VSS.
Jason
brian8702
Sep 4, 2010 08:19 PM
s13_240sx_92
Jul 26, 2005 04:17 PM
Root79
Sep 26, 2004 11:10 PM
FSTASNTZ
May 27, 2004 07:30 AM
