any 4th gen turbo peeps in here
Old Sep 7, 2001 | 09:55 PM
civbeater90's Avatar
Default any 4th gen turbo peeps in here
any of you guys run ac with your turbo?any help would be greatly appreciated.
Old Sep 8, 2001 | 04:44 PM
97 TYPE-R 312's Avatar
Default Re: any 4th gen turbo peeps in here (civbeater90)
A/C is removed and the battery is in the trunk.
Thanks,
Victor Perri II
Old Sep 8, 2001 | 07:25 PM
Smoothy's Avatar
Default Re: any 4th gen turbo peeps in here (97 TYPE-R 312)
There was no room for AC. Plus it was old and I never used it, even when it was hot. I didn't even know if it still worked.
Old Sep 9, 2001 | 08:56 AM
BigBlockCRX's Avatar
New User
if you want to run a/c with your turbo, get a greddy kit
replace your radiator with a 92-2000 civic ( the small one) and cut your radiator hose to fit the radiator.
it works fine and leaves plenty of room for turbo
with the possibility for a/c
Old Sep 10, 2001 | 05:45 AM
WuShu's Avatar
New User
Default Re: any 4th gen turbo peeps in here (BigBlockCRX)
only problem ive seen some of my friends run into is over heating issues, so get an oil cooler. the hard thing about putting in a turbo is basically fitting it in there and then running ac with it causes it to overheat, i say get yourself a nice oil cooler, put your battery in trunk get a teg dual core radiator and remove the winshield washer fuild reservoir. This should all give you way more clearance for a turbo, you can mount your oil cooler where the resevoir was, and without the battery youll have clearance for the pipes, dual core teg radiator will give you room for the turbo itself. just clean out as much stuff as you can in there.
Old Sep 10, 2001 | 03:55 PM
kahren's Avatar
didu know that your turbo pretty much workes liek your ac....
i forgot what i was gonna say but umm yeah good luck
HONDATAD16
Mar 11, 2013 12:18 PM
MAFDARK
Oct 17, 2006 09:54 AM
boostedsc61
Aug 9, 2006 09:35 AM
InTeGrA B18b1
Feb 13, 2004 01:13 PM
