Question for those using a JDM ITR Cluster...
I recently installed a JDM ITR cluster in my Teg... When I unplugged the stock cluster, there where three plugs plugged in, two blue and one yellow... When I plugged in the JDM ITR cluster, there wasn't a space to plug in the third yellow plug, only the first two blue plugs... So I installed it anyway to see what wouldn't work... It's the fuel gauge...
If anyone has installed this into their car before, and know an easy way to make it work please let me know... I guess I could gauge it by how many miles to a tank, but it reads in kilometers so it wouldn't exactly be accurate... TIA...
Dustin here are a couple more links i found as well, looks like the year cluster plays a big role. Is this cluster from a pre 98? Seems this is where the problem lies, but check threads to see hwo to bypass it.
https://honda-tech.com/zerothread?id=605502
https://honda-tech.com/zerothread?id=627945
when i had a jdm cluster i just changed the faces.....maybe the fuel gauge is broken..isn't the little yellow plug for the airbag?
