How do you remove the gauge cluster?
OK, I know about the first 2 screws, it was actually pulling the bezel out that I can't figure out. When I tried to pull it out after removing the screws, it felt like it was gonna break before I could get it out. ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmarlette »</TD></TR><TR><TD CLASS="quote">OK, I know about the first 2 screws, it was actually pulling the bezel out that I can't figure out. When I tried to pull it out after removing the screws, it felt like it was gonna break before I could get it out. ???</TD></TR></TABLE>
That's is how it is... Slide the bottom of the bezel out first, then grab from behind and just give it a firm tug... Don't rip on the ****, just firmly tug and it should come out....
my light is kinda dark compare to other teggys. do i need to change the light bulb?? if i do, where can i get the bulbs?? and the what kinda bulb?? <--- don't have a manual to look at. thanks.
It does feel like it's going to break when you pull it out. There's clips on the cluster and they don't agree with it coming out when you tug on it. You just have to give it a real nice pull for it to come out. After you get it out the first time the other times will be easier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wanna b R »</TD></TR><TR><TD CLASS="quote">ur turn signal bulbs the small one!</TD></TR></TABLE>
aka 194's
aka 194's
If you want brighter, use a 168, not a 194. They are essentially the same, except the 168 is higher wattage, so its brighter.
AcuraIntegra_19_94
Jan 25, 2009 10:25 PM
ferrarifreak93
Jun 5, 2005 10:32 PM
