Problem with speedo in 92 hatch
Old Nov 6, 2003 | 06:28 AM
c1civic's Avatar
Default Problem with speedo in 92 hatch
i swapped in a SI motor wired v-tec *properly* and now my speedo decides when it wants to work i notice it kind of has a trend to work when it is damp out or when it is colder out *to me that sounds like a broke wire somewere* but i checked the grounds and re did them and cleaned the area were they were grounded but now i noticed that my trip and odometer doesnt work all the time either.. if someone could help it would be GREAT! thankz
Old Nov 6, 2003 | 06:38 AM
glagola1's Avatar
Default Re: Problem with speedo in 92 hatch (c1civic)
I had a problem like this and I solved it by replacing the speedo part of the cluster. It would work intermitently and kinda crap out at times.
Don't know what else to tell you.
Old Nov 6, 2003 | 06:49 AM
94EG6HB's Avatar
Default Re: Problem with speedo in 92 hatch (glagola1)
VSS
Old Nov 6, 2003 | 06:52 AM
Ricey McRicerton's Avatar
Default Re: Problem with speedo in 92 hatch (94EG6HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG6HB &raquo;</TD></TR><TR><TD CLASS="quote">VSS</TD></TR></TABLE>
I would guess this over a defective speedometer. These are pretty common problems with our cars. Make sure that it is plugged in good!
Old Nov 6, 2003 | 06:57 AM
c1civic's Avatar
Default Re: Problem with speedo in 92 hatch (Ricey McRicerton)
plugged in well were on the back of the speedo?? i dont know how this could have happend though cause i didnt change anything on the inside of the car though i did swap in a SI motor into a DX body would that have caused the problem?
Old Nov 6, 2003 | 07:00 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
WRONG.
It's the sodering of the speedometer chip. Take the speedo apart and re-soder the sodering on the chip and it should stop doing it. There was a thread a while ago on this.
My speedometer does this too. Usually when the car has warmed up and has run for like 15 minutes it will stop doing it. I'm replacing my cluster with a GSR cluster once I get the time to do it, so that's why I have not re-sodered the speedo chip myself.
If it was your VSS your VTEC would not work, and your speedo would not go on and off.
Old Nov 6, 2003 | 07:07 AM
Default Re: Problem with speedo in 92 hatch (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">If it was your VSS your VTEC would not work, and your speedo would not go on and off.</TD></TR></TABLE>
WRONG. I had a failing VSS before and it was an INTERMITTENT FAILURE. Sometimes my speedo would work and other times it would not.
Old Nov 6, 2003 | 07:31 AM
c1civic's Avatar
what i dont understand is if it was working properly before why would it be doing it now?? if had nothing apart near my speedo or even in my car except when i swapped out the ecu
Old Nov 6, 2003 | 09:52 AM
c1civic's Avatar
bump
Old Nov 6, 2003 | 11:53 AM
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">what i dont understand is if it was working properly before why would it be doing it now?? if had nothing apart near my speedo or even in my car except when i swapped out the ecu</TD></TR></TABLE>
you obviously didnt read my first post?
Old Nov 6, 2003 | 11:54 AM
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
WRONG. I had a failing VSS before and it was an INTERMITTENT FAILURE. Sometimes my speedo would work and other times it would not.</TD></TR></TABLE>
touche!
Old Nov 6, 2003 | 12:07 PM
touche! </TD></TR></TABLE>
See, this is the stuff I like!! I was just being a dick back because you were a dick to this guy . I sure am glad there are some people who can take it like a man and not get into a little internet bitch fight. to you!
Old Nov 6, 2003 | 12:52 PM
H-T Poker champion
See, this is the stuff I like!! I was just being a dick back because you were a dick to this guy . I sure am glad there are some people who can take it like a man and not get into a little internet bitch fight. to you!</TD></TR></TABLE>
Haha.. Well.. You caught me on a good day. Not to mention I know you're right about that, so what's the point of arguing? Thanx for the though.. and here's a few for you.
Old Nov 6, 2003 | 12:55 PM
Haha.. Well.. You caught me on a good day. Not to mention I know you're right about that, so what's the point of arguing? Thanx for the though.. and here's a few for you. </TD></TR></TABLE>
Hell yeah x6 on me!!
Old Nov 6, 2003 | 09:21 PM
94EG6HB's Avatar
But this happened after his swap.
The cluster never changed.
The motor did..
The trip and the odo dying are just a symptom..
Weird coinky dink don't you think?
Old Nov 6, 2003 | 09:25 PM
99blackcivicSi's Avatar
a buddy of mine had a bad VSS and his vtec still worked but he did also have a Vafc if that makes a differance i think it might though.
I would check the VSS first the way that he messed his up and i saw him do this he took the coolant line off of the mani. and it spilled on the VSS and proceeded to corrode because he didn't wipe it off so i would check that first
adobospoon
23
Dec 24, 2006 08:56 PM
civic889802
Jan 25, 2006 10:43 AM
Uniden
13
Sep 2, 2004 06:59 PM
LudeRc51
Apr 23, 2004 12:41 PM
