FS: t3/to4 60-1 (TO4S), 4 bolt Flange... $600
I got a very slightly used 4 bolt t3/t4 60-1, .63 A/R stg3 turbine wheel, .70 A/R (To4S) Compressor housing NEW!
360 deg thrust bearing
500miles on the turbo. It had a hifi (To4e) comp housing before, decided to swap the comp housing, Shipped it back to Cheapturbo to put in a t04s .70 A/R Comp housing. It has a New backplate/comp housing on it. Everything is checked out in perfect condition. $600 shipped
360 deg thrust bearing500miles on the turbo. It had a hifi (To4e) comp housing before, decided to swap the comp housing, Shipped it back to Cheapturbo to put in a t04s .70 A/R Comp housing. It has a New backplate/comp housing on it. Everything is checked out in perfect condition. $600 shipped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsTurbo91 »</TD></TR><TR><TD CLASS="quote">spooled around 3000rpm, fully spooled at 4500rpm</TD></TR></TABLE>
umm... which motor and with what compressor housing?! my t3/to4e .60 compressor .63 turbine spooled at 3300 and full boost at 4500
this was on a ls/vtec stock bore, with a 60 a/r comp housing (to4e). Now it has a to4s, I originally planned on just running it with the upgraded housing but decided to sell it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsTurbo91 »</TD></TR><TR><TD CLASS="quote">this was on a ls/vtec stock bore, with a 60 a/r comp housing (to4e). Now it has a to4s, I originally planned on just running it with the upgraded housing but decided to sell it. </TD></TR></TABLE>
aohhh ok, now it makes sense.
bump for one girthy turbo!
