Any Ideas? Noise Issues.
Old Nov 5, 2003 | 11:52 PM
RIPF23A5's Avatar
Default Any Ideas? Noise Issues.
I just bought an EG Hatch and I have been hearing rocks/pebbles pinging the inside of the wheel well. I took a look today and noticed that there is no black plastic protecting the inside of the well, so all the aluminum is exposed causing very loud, annoying pings everytime I drive over small rocks.
Is there anywhere I can buy the innerplastic piece for the well?
Does anyone have any suggestions as to a different, more DIY solution?
Also, road noise is pretty excessive. Has anyone found ways to deaden the noise a bit?
Will audio Damping material help me out the best? If so, are there any specific brands?
Anyone have any other suggestions?
Old Nov 5, 2003 | 11:54 PM
Pho Real's Avatar
Default Re: Any Ideas? Noise Issues. (RIPF23A5)
Yes you can buy that black part from honda.
Also you are driving a civic, you are going to hear alot of road noise. They do have a few products out there, but if you plan on swapping the engine and making modifications to the car then buying that **** is pointless.
Old Nov 5, 2003 | 11:55 PM
=GAME='s Avatar
go to honda for the inner lining. but if u chose not to purchase that, my guess would be dynamat the inner fender.
Old Nov 5, 2003 | 11:56 PM
=GAME='s Avatar
Default Re: Any Ideas? Noise Issues. (Pho Real)
go to sleep girl. past your bedtime.
Old Nov 6, 2003 | 01:57 AM
mycivicstoo(s)low's Avatar
Default Re: Any Ideas? Noise Issues. (O.G triple O.G)
Dynamat your wheelwells? Mine does that too, I don't know why there wasn't a lining on it.
Old Nov 6, 2003 | 11:52 AM
RIPF23A5's Avatar
Default Re: Any Ideas? Noise Issues. (mycivicstoo(s)low)
looks like the bomper was taken off, so it looks like it was never put back on.
Where is the best place to buy a honda part like that?
Is there somewhere cheaper than the local honda dealership?
Old Nov 6, 2003 | 12:11 PM
2000SS's Avatar
A cheaper alternative would be a lynex coating or something similar. They do sell at the autoparts store what they call Under Carriage Coating. It sells for about $6.95 a can. My truck was extremely loud in the cabin without any floor carpeting or sound deadening material, until i had sprayed the floor board with it and added some carpet. It would not only help deaden the sound, but help protect the body from any rust. Only drawback is it takes a couple days to set up.
Old Nov 6, 2003 | 10:56 PM
RIPF23A5's Avatar
Default Re: Any Ideas? Noise Issues. (2000SS)
I like the sound of the lynex idea. Is it mostly self-explanitory, or is there anything I should know prior to spraying? Are there any precautions I should take or is there any special prepping involved? Do you have pictures of how it was done, or know where I can find any?
Thanks
Old Nov 6, 2003 | 11:33 PM
zelifcam's Avatar
the parts you need are called Inner Fender Liners from Honda. they are quite expensive and flimsy and crappy. If you have big wheels they will rub them out.
kenskii
Jul 8, 2014 08:33 PM
Hondacivic90ed
28
Jan 18, 2009 05:47 AM
HondaScott
Honda Civic (2001 - 2005)
Oct 25, 2006 11:48 PM
makri
Feb 3, 2006 09:03 AM
