code 14 iacv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_a$$_si »</TD></TR><TR><TD CLASS="quote">i had this code for two months and i finally replaced it, but its still throwing the cade. when i hold the gas pedal little bit it revs up and down at 1500rpm. now what?</TD></TR></TABLE>
does this only happens once in a while or everytime? i have the same problem now but only after driving for a little while. does it hesitate when youre in 1st and want to go? usually ill just turn the car off and turn it back on and itll go away for a while and comes back again.
to reset the ecu unplugged the negative battery terminal for bout 5 seconds...if you still throw the code adjust the iac screw on the TB down a lil (right for low left for high) and keep playing with that till it goes away mine did the same thing
