Prelude tail lights
the easiest way to do it, is put one of them in the over at 250 degrees checking it every few minutes, just to unmelt the glue then pry the lense off. once you get it apart, i'm pretty sure the yellow part just comes out if you pull it out, not sure though, i lost the write-up and i haven't gotten around to doing this yet
What was said above is true.
The amber/clear part snaps out, and you replace it with a piece of flourescent light cover that you cut to the same size as the piece you took out, and silicone it in the stock location.
I just did this on a broken tail light tonight actually. Came out alright but this light is cracked anyways so it wont be going on my car.
Just an idea of how it looks.
The light is not pressed all the way back together so if you see gaps that is why.
i tried to do mine last week and i destroyed mine. How did you guys get them apart with out making a ton of little marks from the tools that you use to take them apart?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">I just used a hot-air gun; i was too afraid to try the oven thing.</TD></TR></TABLE>
i wish i had one, the oven scares me but i didnt have another option when i did mine
STREETFIGHTER50
Honda CR-V & Element
Jul 7, 2018 01:40 PM
EvenStar
Dec 19, 2006 11:59 AM
