Advancing the timing
Old Nov 5, 2003 | 07:27 PM
quicksol95's Avatar
Default Advancing the timing
What is most you would advance a D15 and a D16 from the stock timing. What should I except to gain or lose? and What will the total timing be at when I am done?
Thanks
JDMlyfestyle's Avatar
you wont gain all that much. maybe 1 or 2 if your lucky
Old Nov 5, 2003 | 07:33 PM
quicksol95's Avatar
Default Re: (JDMlifestyle)
what can i advance it to though
Old Nov 5, 2003 | 07:41 PM
Nextelbuddy's Avatar
like he said you wont gain anything form it. not on a d15 or d16. its not worht the risk of advancing timing. just listen and dont be stubbron and do it anyways. save some money and get a better motor or at least spend money on MODS that will actually give real gains instead of cheap free mods like that that dont do anything
Old Nov 5, 2003 | 07:49 PM
EGinNY's Avatar
Default Re: (slowsohccivic)
if your going to advance go no more then 2 deg. towards the firewall, your only possible improvement will be throttle response
Old Nov 5, 2003 | 08:01 PM
LSVtecEK1's Avatar
you dont notice anything, but we advanced the timing on my friends single cam all the way to see what it did......nothing really, no extra power
Old Nov 5, 2003 | 08:15 PM
Gets some serious mods, cam cam gear internals then play with the ignition timing thats the only time when it is useful. Not for lil things like intake and exhaust. You will learn alot here on HT
Old Nov 5, 2003 | 09:05 PM
civic_tuned's Avatar
Default Re: Advancing the timing (slowsohccivic)
dont mess with the timing if u dont know what ur doing.
Old Nov 5, 2003 | 09:58 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Advancing the timing (civic_type_r)
Advancing the timing won't do anything if you dont' do it right. I.E. - Let the car warm up, jump svc connector etc.... Manual recomends stock timing +/- 2 degrees.
Example B-Series 14-18 degrees. D-Series not sure.
Old Nov 6, 2003 | 08:15 AM
quicksol95's Avatar
what the heck i s"jump svc connector etc." mean
Old Nov 6, 2003 | 08:16 AM
quicksol95's Avatar
Default Re: Advancing the timing (Mr Milano)
what are the best mods for my car
thanks
Old Nov 6, 2003 | 08:18 AM
JDM-97CX's Avatar
try here for mods for your car
https://honda-tech.com/zerosearch
Old Nov 6, 2003 | 08:25 AM
quicksol95's Avatar
Default Re: Advancing the timing (JDM-97CX)
No Results Found
Your search for d16 mods returned no results.
Please try different search criteria or a different data set.
Old Nov 6, 2003 | 02:36 PM
EGinNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsohccivic &raquo;</TD></TR><TR><TD CLASS="quote"> No Results Found
try typing in something other then just d16 mods......be creative
Old Nov 6, 2003 | 03:22 PM
tangb2023
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Example B-Series 14-18 degrees. D-Series not sure.</TD></TR></TABLE>
d series is the same.. just leave it at 16 degree.. no use ******* with it.. i dont even do it to any one of my b series motor..cause there is no improvement..better off getting new spark plugs..plus leaving the timing as manufactures specs .. is fo maximum hp and max feul economy.. that is the whole purpose..unless u got cams and ****..
Old Nov 7, 2003 | 06:31 AM
You can start off with the basic Mods on ur D16. I/H/E. then get a skunk 2 intake man. 62 mm throttle body.Then go to the head. Get it cleaned up. New valvetrain,get a good head job 3 angle valve job. A nice cam like the zex street/strip cam. a cam gear. Then Get a VAFC and tune it. If your not happy with that then time to get to the guts of the motor. There are nameless combonantions you can do with rods and pistons. But its all up to you. After that if you arent satisfied go FI. there ya go bucko
Old Nov 18, 2003 | 01:00 PM
tgreaves's Avatar
What car is this.. If its a dx crx you could do the mpfi swap.. If you have a D15B2 or B7 block you could do the mini-me vtec swap on it..
Old Nov 18, 2003 | 03:49 PM
righteyeblind's Avatar
put it at 38 degrees total advanced and then you dont have to worry about detonating or anything
Old Nov 18, 2003 | 04:25 PM
Knightmare69's Avatar
I was told that advancing the Distributor 2 degrees would help improve the D16Y8. Any truth to that?
Treyschls
Apr 13, 2023 07:04 AM
1.8Tities
Sep 8, 2002 03:32 AM
hondacivic4g
Jul 16, 2002 12:33 PM
OneFastLS
May 25, 2002 03:12 PM
