so many probs with zc
Old Nov 5, 2003 | 05:59 PM
second edition's Avatar
Default so many probs with zc
im throwing a code 43 in my zc. The cel comes on when ive been driving for a constant speed for a wile. The car also heitates around 3000 rpms when the engine is cold and the idle is terrible until the car gets up to temp. I have replaced the fuel pump(gsr),fuel filter, fuel pressure is good.It has new plugs, wires,cap,rotar and whole new dist.It also have a new o2 sensor. Im running the car off of a reprogramed dx ecu. its in a 5th gen by the way, but you guys n=know more about the motor.ive tried searching and found lots of results,but none helped. please help. im on my last straw with this thing
Old Nov 5, 2003 | 06:02 PM
91civicEX's Avatar
the reprogrammed dx ecu COULD be the problem. try a pm6 that should be pretty easy to find. i dont think code 43 exists
Old Nov 5, 2003 | 06:20 PM
90crxzc's Avatar
Default Re: so many probs with zc (second edition)
i agree, the ecu could be the problem, where are u located? a have a pm6 u can try it with
Old Nov 5, 2003 | 06:23 PM
im in madison wi
Old Nov 5, 2003 | 07:07 PM
jlicrx's Avatar
code 43 is fuel system on OBD1 car - do you have OBD1 ZC? you said in 5th gen, which is OBD1 - what is the ECU? OBD0 or OBD1? just trying to figure out what you have - makes it easier to help out
Old Nov 5, 2003 | 07:08 PM
its the factory dx ecu that came with the car. its also a obd-1 motor
Old Nov 5, 2003 | 07:46 PM
DJ_SaNdOz's Avatar
Default Re: (second edition)
Is that the P08 ECU? Where did you get it chipped? A friend? A shop? Ebay? Have you tried any other ECU's? More info would be great.
Old Nov 5, 2003 | 08:01 PM
its got a po6. it was chiped at hasport by a friend of my tuners. The same guy who suposedly does thier harnesses.
brent_G's Avatar
Default Re: so many probs with zc (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">code 43 is fuel system on OBD1 car - do you have OBD1 ZC? you said in 5th gen, which is OBD1 - what is the ECU? OBD0 or OBD1? just trying to figure out what you have - makes it easier to help out</TD></TR></TABLE>
my friends b18b1 in his crx running obd0 had the same problem..i even tried my obd0 ecu and still threw the same code. I didnt get it since obd0 should be only codes 1-20....so im am also lost with this too...friend would also like to know if anyone figures it out
Old Nov 6, 2003 | 05:42 AM
DJ_SaNdOz's Avatar
Have you talked with slowcivichmm at all? He is running a ZC in a 5th gen. he may have some insight.
Old Nov 6, 2003 | 06:14 PM
i dont think its the ecu because ive had it in the car for bout 4 months and i just started geting the cel.........thanks for all the replies.
Old Nov 6, 2003 | 06:26 PM
Project91CRX's Avatar
well, we need a little recap..
Which Year ZC? 88-89 is OBD-0. 90-91 is obd-1
What car is this on? What ECU are you using.
Reason asking is because there's so many ZC out there. There's the JDM DOHC ZC, JDM SOHC ZC, USDM ZC from Integra which was stamped a D16
Old Nov 6, 2003 | 06:37 PM
virginia_dude's Avatar
Default Re: (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">the reprogrammed dx ecu COULD be the problem. try a pm6 that should be pretty easy to find. i dont think code 43 exists</TD></TR></TABLE>
Um isn't the DX ecu a DPFI unit a PM5 I am sitting here looking at my old one as I speak. How do you reprogram a DX ecu that feeds two fuel injectors to work on a MPFI with four? that would take a whole lot more than just programming. Ok I just saw the ODB-1 thing but thought even the newer ones wee DPFI.(the DX)
Old Nov 6, 2003 | 08:16 PM
its a 94 dx coupe. obd-1. its a obd-1 motor as well. im running it on the stock ecu reprogramed and yes it is a po6 for sure.
alx_90ef
12
Mar 24, 2010 06:17 AM
RACEPAK
Nov 30, 2007 07:56 AM
deerek101
Feb 5, 2006 09:44 PM
sLoWrAcEr
Jun 22, 2005 10:17 AM
