CTR cluster question....(searched already)
Old Nov 5, 2003 | 03:05 PM
Petah's Avatar
Default CTR cluster question....(searched already)
I just installed a CTR cluster into my 2000 DX hatch and everything works perfectly EXCEPT for the dimmer switch. I used to have the EG6 SiR cluster in my 92 SI and the dimmer didn't work either. Anyone has the same problem?
Old Nov 5, 2003 | 03:07 PM
Dr. EKology's Avatar
Default Re: CTR cluster question....(searched already) (Petah)
I've got the JDM EK4 SiR cluster in mine and my dimmer doesn't work either.
Old Nov 5, 2003 | 03:12 PM
Cav's Avatar
Cav
Default Re: CTR cluster question....(searched already) (EVIL_EKology)
ah man who needs a dimmer switch
i honesly never adjust mine, dont you wanan show off the jdm red anyway????
Old Nov 5, 2003 | 03:13 PM
hontegra's Avatar
check the wires going into the plugs.check the wiring diagrams.
Old Nov 5, 2003 | 03:14 PM
Petah's Avatar
Default Re: CTR cluster question....(searched already) (Cav)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cav &raquo;</TD></TR><TR><TD CLASS="quote">ah man who needs a dimmer switch
i honesly never adjust mine, dont you wanan show off the jdm red anyway????</TD></TR></TABLE>
Nah.....i am too old and the birghtness is hurting my eyes!
Old Nov 5, 2003 | 03:15 PM
Petah's Avatar
Default Re: (hontegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hontegra &raquo;</TD></TR><TR><TD CLASS="quote">check the wires going into the plugs.check the wiring diagrams.</TD></TR></TABLE>
I don't mind checking the wires and all, just want to make sure it's not a known problem with CTR clusters because i know with the EGs, there is no way in getting the dimmer to work with a JDM SiR cluster.
Old Nov 5, 2003 | 05:43 PM
Petah's Avatar
Default Re: (Petah)
anyone else?
Old Nov 5, 2003 | 06:28 PM
built562's Avatar
Default Re: (Petah)
there is no dimmer swtiches on jdm cars, so your usdm dimmer wont dim the jdm clusters. they dont dim. period
Old Nov 5, 2003 | 06:42 PM
Ricey McRicerton's Avatar
Default Re: (akumaracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer &raquo;</TD></TR><TR><TD CLASS="quote">there is no dimmer swtiches on jdm cars, so your usdm dimmer wont dim the jdm clusters. they dont dim. period</TD></TR></TABLE>\
Yup what he said. I'm sure you could rig something up, but they don't work without a little extra wiring.
Old Nov 5, 2003 | 06:52 PM
Kool305's Avatar
heh...yeah what he said
Old Nov 5, 2003 | 06:55 PM
JDM-97CX's Avatar
Default Re: CTR cluster question....(searched already) (Kool305)
yea no dimmer on the jdm cars
Old Nov 5, 2003 | 07:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah &raquo;</TD></TR><TR><TD CLASS="quote">
Nah.....i am too old and the birghtness is hurting my eyes! </TD></TR></TABLE>
Brightness?? Anyone know how I can get mine brighter??
Old Nov 5, 2003 | 07:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_EKology &raquo;</TD></TR><TR><TD CLASS="quote">
Brightness?? Anyone know how I can get mine brighter??</TD></TR></TABLE>
Get some Hyper Whites . I realy have no idea man.
Old Nov 5, 2003 | 07:47 PM
Petah's Avatar
The CTR cluster is alreaduy plenty bright compared to my old EG SiR cluster.
EK MONEY's Avatar
This is true.
Old Nov 5, 2003 | 08:07 PM
94EG6HB's Avatar
Default Re: (Peagreenhatch)
No dimmer..
That's the way it is.
Anybody know if EDM civics came with a dimmer.
Old Nov 5, 2003 | 08:12 PM
Default Re: (94EG6HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG6HB &raquo;</TD></TR><TR><TD CLASS="quote">No dimmer..
No, they did not.
Old Nov 5, 2003 | 08:14 PM
Chris y0!'s Avatar
dimmer doesn't work because there is no dimmer.
cablamo-
Old Nov 5, 2003 | 08:19 PM
EG2 SiR's Avatar
Default Re: (Chris y0!)
I am not sure about the CTR cluster but I removed the dimmer potentiometer from my USDM del sol cluster and installed it to work on my JDM Del Sol cluster. There is not way to adjust it because it sits behind the cluster, but you can make it bright and leave it that way.
Old Nov 5, 2003 | 08:22 PM
Fowler.'s Avatar
Default Re: (EG2 SiR)
I have an EK4 cluster and my dimmer works. Woot!
Old Nov 5, 2003 | 08:24 PM
Chris y0!'s Avatar
Default Re: (Fowler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fowler &raquo;</TD></TR><TR><TD CLASS="quote">I have an EK4 cluster and my dimmer works. Woot!</TD></TR></TABLE>
que?
Old Nov 5, 2003 | 08:31 PM
Fowler.'s Avatar
There is something fishy with it. I think the guy that I bought it from used a usdm backing or something. I was a little bit suprised when I noticed it worked.
Old Nov 6, 2003 | 02:12 PM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fowler &raquo;</TD></TR><TR><TD CLASS="quote">There is something fishy with it. I think the guy that I bought it from used a usdm backing or something. I was a little bit suprised when I noticed it worked.</TD></TR></TABLE>
that's what I did with my EG2 cluster... but I had to zip tie the potentiometer to the rear of the cluster since there is no hole for the **** through the cluster.
Old Nov 6, 2003 | 02:53 PM
ChadB's Avatar
When the dimmer is taken off, will your lights stay the same as of the last time, you set them???
ej6fade
Mar 22, 2012 10:39 AM
Sean @ ESG
Oct 4, 2008 06:45 PM
93Civic_hb
Apr 4, 2008 03:50 AM
nub.96ek
Nov 5, 2004 01:02 AM
zseeanz
Oct 19, 2004 07:53 PM
